I have both, and though I don’t measure grams, to my feeling, the lenses are the same on the camera (size/weight). I use the lux for portraits only, the zoom is for all other stuff and a portrait if I don’t carry the lux.
without adapter, you won’t be able to come close enough for macro work.
The 24-90mm weighs 1,140g has a reproduction ratio of 1:3.8 and a MFD of 0.30 meters vs the Summilux SL 50mm’s reproduction ratio of 1:10, weight of 1,065g and MFD of 0.60 meters.
Edited by Hanno
  • 1 month later...
I have both, 24-90 and 50 lux, and grabbed one thinking it was the other more than once.  I now purposefully look at which one I pick up to be sure it's the one I want.  I did shoot some "macro" shots with the lux of my wife's orchids and it did all I wanted it to do.
Edited by ALScott
  • 3 weeks later...
I tried the fotodiox extension tube with the Summilux SL and was never happy with the results.  I don't own the 24-90 anymore, but it could definitely get closer.
If I were looking for a macro solution, I would just go with the Panasonic Lumix 100 mm f/2.8 macro.  It's a stellar lens (and that's coming from someone who owns the 21, 35, 50, and 75 APO Summicron-SLs and the 50 Lux SL).
With a MFD of 60cm and a reproduction ratio of 1:10, I am not sure how the Summilux SL 50 would be a good choice for macro photography, unless I am missing something.
I am not doing much macro, but I understand that macro lenses would at least go for 1:2 and ideally 1:1 reproduction ratio and MFD of 30cm.
You would be better off with the Summicron-SL APO 50mm with 35cm MFD and 1:5 reproduction ratio though still not ideal.
Edited by Hanno
