Hi,
I got this used Leica Summarit-M 50 2.5 lense online, after a through check, I have noticed there are quite some marks on both side of the aperture blades.
Just would like to know:
1: What might be the reason causing these marks? Just some wear marks? Small hard particles stuck between blades? Or damaged by CLA guy?
2: Will it get wrose? Should I send to CLA again?
3: I am not sure this is a severe problem or not, at least I have not seen other lense has more marks than mine :(
Thank you for your kindly reply :)
22 hours ago, TommyTang said:
Hi,
Perhaps you should be more concerned about the blue spot on the diaphragm blades.
It looks like a classic case of Skybluespotitis, which can cause the diaphragm blades to move far more quickly than they should.  This is usually a result of ultra-violent light entering lens and shattering the light into individual wavelengths that cause problems when they're reassembled into the full spectrum.
Pete.
PS, I might have made all of that up.  Even the ultra-violent light.
  • Haha 2
