jaapv Posted August 23, 2024 Share #1 Posted August 23, 2024 Advertisement (gone after registration) It is fragile ( I already broke one on the 150-600 which is the same dodgy construction whilst the lens was inside a padded bag). It is huge. It is a pain to remove and replace. It blocks the zoom ring when reversed and impairs it when mounted. Fortunately Amazon has the solution. An elegant collapsible rubber screw-in hood of exactly the same dimensions at a mini price, part of a kit at 10(!) €. I ordered a metal one for the 150-600 which will arrive next week. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/402794-70-200-i-hate-that-lens-hood-i-found-the-solution/?do=findComment&comment=5497062'>More sharing options...
Advertisement Posted August 23, 2024 Posted August 23, 2024 Hi jaapv, Take a look here 70-200. I hate that lens hood- I found the solution . I'm sure you'll find what you were looking for!
kkochheiser Posted August 23, 2024 Share #2 Posted August 23, 2024 Ordered, thank you! 1 Link to post Share on other sites More sharing options...
jaapv Posted August 23, 2024 Author Share #3 Posted August 23, 2024 I still have to figure out what to do with that tuliphood and the odds and ends that come with it...🤔 Link to post Share on other sites More sharing options...
lawman Posted August 27, 2024 Share #4 Posted August 27, 2024 On 8/23/2024 at 11:28 AM, jaapv said: It is fragile ( I already broke one on the 150-600 which is the same dodgy construction whilst the lens was inside a padded bag). It is huge. It is a pain to remove and replace. It blocks the zoom ring when reversed and impairs it when mounted. Fortunately Amazon has the solution. An elegant collapsible rubber screw-in hood of exactly the same dimensions at a mini price, part of a kit at 10(!) €. I ordered a metal one for the 150-600 which will arrive next week. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! jaapv - what make metal hood did you buy for the 150-600 - and was it also from Amazon?? Thanks Link to post Share on other sites More sharing options...
jaapv Posted August 27, 2024 Author Share #5 Posted August 27, 2024 I have not received it yet. I’ll report as soon as I get it. Link to post Share on other sites More sharing options...
lawman Posted August 28, 2024 Share #6 Posted August 28, 2024 Jaapv - thanks for the recommendation - just received mine - no idea how they can do it so cheaply - almost embarrassed to put onto the lens!! Have you tried the plastic petal hood? Does it allow flare at either end or do you think it could work? Thanks Link to post Share on other sites More sharing options...
jaapv Posted August 28, 2024 Author Share #7 Posted August 28, 2024 Advertisement (gone after registration) I have no wideangle to put it on. It is far too wide for 70 mm. Bottom of the drawer stuff. Link to post Share on other sites More sharing options...
jaapv Posted September 2, 2024 Author Share #8 Posted September 2, 2024 On 8/27/2024 at 3:07 AM, lawman said: jaapv - what make metal hood did you buy for the 150-600 - and was it also from Amazon?? Thanks Fotga. Exceedingly well built and solid No vignetting. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/402794-70-200-i-hate-that-lens-hood-i-found-the-solution/?do=findComment&comment=5532303'>More sharing options...
lawman Posted September 19, 2024 Share #9 Posted September 19, 2024 On 9/2/2024 at 10:07 AM, jaapv said: Fotga. Exceedingly well built and solid No vignetting. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Jaapv - do you use filters with this hood, and if so, do you put them on the lens first, or on the hood outer threads? Thanks- Larry Link to post Share on other sites More sharing options...
jaapv Posted September 19, 2024 Author Share #10 Posted September 19, 2024 On the lens and then screw in the hood. A filter should be as close to the lens as possible. Link to post Share on other sites More sharing options...
lawman Posted September 19, 2024 Share #11 Posted September 19, 2024 Agreed — just wanted to be sure no vignetting with a filter attached - thanks - nice hood🤗 Link to post Share on other sites More sharing options...
tom0511 Posted September 25, 2024 Share #12 Posted September 25, 2024 Are we talking about the sports 70200 Sigma? I don't find it that bad so far, I also like its rubberized at the front so you can put the lens on it when its not mounted on the camera, or when you touch something with it. I also would assume its better protection for the lens if you touch something with the front of the lens. Anyways, thank you for sharing alternatives. Always good to know. Link to post Share on other sites More sharing options...
jaapv Posted September 26, 2024 Author Share #13 Posted September 26, 2024 It is not much of protection. The one on my 150-600 which is the same but larger broke to pieces after a few weeks - inside the bag. And it blocks the front bit of the zoom ring. I have -needed for my use- IR cut filters on my wildlife lenses anyway. Link to post Share on other sites More sharing options...
