Mo Elsaghir Posted August 19, 2024 Share #1  Posted August 19, 2024 Advertisement (gone after registration) I recently acquired Panasonic Lumix 28 200mm lens to use on my Panasonic S! and it works as a full frame. When I mount it on my Leica SL 601 it goes to crop mode !!  Is it faulty lens or it does not work if full mode with Leica sl ? I also noticed the same behavior with the Panasonic 20 60mm on the Leica SL Help Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 19, 2024 Posted August 19, 2024 Hi Mo Elsaghir, Take a look here Help with Panasonic lumix s 28 200mm lens compatibility with Leica SL. I'm sure you'll find what you were looking for!
SrMi Posted August 19, 2024 Share #2  Posted August 19, 2024 15 minutes ago, Mo Elsaghir said: I recently acquired Panasonic Lumix 28 200mm lens to use on my Panasonic S! and it works as a full frame. When I mount it on my Leica SL 601 it goes to crop mode !!  Is it faulty lens or it does not work if full mode with Leica sl ? I also noticed the same behavior with the Panasonic 20 60mm on the Leica SL Help Do you have the latest 4.1 firmware update for SL? https://leica-camera.com/en-US/downloads?download_area_category=1171&field_media_document_language=984 Quote Link to post Share on other sites More sharing options...
Mo Elsaghir Posted August 19, 2024 Author Share #3 Â Posted August 19, 2024 No I have 4, You have I point, maybe I should update mine before making assumptions Thanks Quote Link to post Share on other sites More sharing options...
SrMi Posted August 19, 2024 Share #4 Â Posted August 19, 2024 1 hour ago, Mo Elsaghir said: No I have 4, You have I point, maybe I should update mine before making assumptions Thanks Let us know if it fixed it. Quote Link to post Share on other sites More sharing options...
geraldc Posted August 20, 2024 Share #5  Posted August 20, 2024 I have also recently acquired the Lumix 28 to 200 for use on my SL3. Works perfectly at full frame. Initial shots are very encouraging. Visually a bit soft at 200. Focusing is very snappy and it has inbuilt OIS. Going on a 2 week trip in early September. I will bring this together with a 35 APO (as standby!). Quote Link to post Share on other sites More sharing options...
Mo Elsaghir Posted August 20, 2024 Author Share #6 Â Posted August 20, 2024 I have updated the firmware and it fixed the problem Thanks everyone for your help, I will try the lens properly and let you know. 1 Quote Link to post Share on other sites More sharing options...
Mo Elsaghir Posted August 23, 2024 Author Share #7 Â Posted August 23, 2024 Advertisement (gone after registration) I have now updated my SL and the lens works very smoothly with the camera. Very fast focusing and as someone mentioned slightly soft at 200mm but colours are vibrant . It is outdoor lens in my opinion and easy to carry all day, as a one lens. Very pleased with it from practical point of view, I do not have to worry about which focal length lenses to carry on short outing. Will be going on short break to Wales soon. Looking forward to taking this one on its own. 1 Quote Link to post Share on other sites More sharing options...
