kengai Posted August 7, 2024 Share #1 Posted August 7, 2024 Advertisement (gone after registration) I would like to get a medium telephoto mainly for portraits. Between the 75 and 90mm which one should I choose? Link to post Share on other sites More sharing options...
Advertisement Posted August 7, 2024 Posted August 7, 2024 Hi kengai, Take a look here leica 75 or 90?. I'm sure you'll find what you were looking for!
spydrxx Posted August 7, 2024 Share #2 Posted August 7, 2024 I've used an older Leica 90/4 Elmar as well as a more modern Voigtlander 75/2.5. The Elmar gives more of a classic look while the Voigtlander is crisper, giving a modern look. Depending on the type of portraits you are doing, male vs female especially, you may find one focal length more suitable than the other. I think the 90 requires a little more finesse focusing on the eyes than the Voigtlander, but much prefer its flatter rendering for female portraits. Link to post Share on other sites More sharing options...
Olaf_ZG Posted August 7, 2024 Share #3 Posted August 7, 2024 3 hours ago, kengai said: I would like to get a medium telephoto mainly for portraits. Between the 75 and 90mm which one should I choose? Indoor or outdoor? Do you have the space to go 90? Link to post Share on other sites More sharing options...
Ralf Posted August 8, 2024 Share #4 Posted August 8, 2024 Either one will do the job, once you get to use it properly. Link to post Share on other sites More sharing options...
hlansing Posted August 9, 2024 Share #5 Posted August 9, 2024 What other lenses do you already have? I chose 90 since I already had a 50 and felt that 75 would be too close in FL. If I had a 35 then I would chosen a classic 35/75 pairing. Link to post Share on other sites More sharing options...
Dr. G Posted August 9, 2024 Share #6 Posted August 9, 2024 11 minutes ago, hlansing said: What other lenses do you already have? I chose 90 since I already had a 50 and felt that 75 would be too close in FL. If I had a 35 then I would chosen a classic 35/75 pairing. I have the 21/35/50/75 APO and the 50mm Summilux-SL. I like the 50 APO and 75 APO for different reasons. FWIW, I do a lot of close up photography so there is a big difference between 50mm and 75mm in that case. I can't shoot my at my usual working distance for most things with the 75. The 50 APO is great for closer shooting. Link to post Share on other sites More sharing options...
robb Posted August 10, 2024 Share #7 Posted August 10, 2024 Advertisement (gone after registration) I think both are almost twins. i agree that it depends mainly on how much room you have to shoot and the compression you like. 75 apo is my favorite lens ever made… and I also love using the 90 Robb 1 Link to post Share on other sites More sharing options...
