I would like to use my OSBLO telescope adapter with my 80-200 Vario Elmar R. The problem is I cannot seem to find an R lens to LTM adapter, as the OSBLO is LTM. Does anyone know if any company ever made an R lens to LTM adapter or is there another way to "catchee monkey" . My maths says the adapter should be 18.2mm deep (47.0-28.8).
Wilson
this one ?
https://www.dagcamera.com/store/p225/Leitz%2C_Leica_Original_R_to_Screw-Mount_Testing_Tool%2FAdapter.html
these  rare adapters should be 3d scanned
Edited by frame-it
4 hours ago, Michael Geschlecht said:
Hello Wilson,
Did you try a Novoflex LEI-F?
A Leicaflex/Leica-R lens to Leica screw mount body adapter.
Best Regards,
Michael
Many thanks Michael, I found one on Fleabay from a German trade seller at a not unreasonable €69.
vor 7 Stunden schrieb Michael Geschlecht:
Note that the LEI-F is made for using Leica R lenses on a bellows. This is why it is is NOT 18.2 mm deep to keep infinity focus, but only about 10 mm.
Edited by dg4mgr
I wish I had known that before buying one. What a weird decision. R lenses have their own excellent bellows system in the 16880-BR-2 bellows system which I already have. I do have a set of L39 extension tubes (Periflex) which may solve the problem
Wilson
Hello Wilson,
If this adapter needs to be 18.2mm deep to accept a Leicaflex/Leica-R lens & have the lens be focused at Infinity when the lens is set at Infinity.
And the adapter LEI-F is about 10mm deep.
Won't the lens extension available when focusing the 80-200 Vario-Elmar be more than the 8.2mm necessary to bring the lens to focus at Infinity when the lens focus barrel is focused to closer distances?
Until you can locate a Leica Thread extension tube, or a set of Leica Thread extension tubes, that total around 8.2mm.
There is a Leica Thread extension tube 14020 which is 15mm deep.
Best Regards,
Michael
Edited by Michael Geschlecht
I am delighted to say that the LEI-F adapter does enable my 80-200 Vario Elmar-R lens to be used as a telescope with the OSBLO. The focussing on the lens allows for the shallower than mathematically ideal adapter, to focus from quite close distances to infinity. The only downside is that the telescope is a bit like an early 19th century marine telescope with quite a small exit pupil, so you have to keep your eye well centred.
Wilson
