michaelbrenner Posted June 30, 2024 Share #1 Posted June 30, 2024 Advertisement (gone after registration) I have a vintage 21mm finder, which at first fit properly in the flash shoe of my M11. However, now it fits so loosely that it will slide off, unless I wedge it in there with something (I usually use a toothpick on each side). The digital finder continues to fit with no issues. Any ideas on how to remedy this situation? Link to post Share on other sites More sharing options...
Advertisement Posted June 30, 2024 Posted June 30, 2024 Hi michaelbrenner, Take a look here M11 Flash Shoe Spring Flattened. I'm sure you'll find what you were looking for!
erl Posted June 30, 2024 Share #2 Posted June 30, 2024 Leica need to redesign the hot shoe. My M10 has the same issue. I have lost two EVF's as a direct consequence, at great expense to self. The same EVF's fit perfectly in my M6,7,8 and 9, but the M10 hot shoes is a design disaster. I have had Leica Service 'adjust' the springs but the result is pathetic. My solution is to insert a small piece of insulation tape to 'jam' the shoe when inserted. Most inelegant as a bit of engineering, but it works. 1 Link to post Share on other sites More sharing options...
kyono Posted June 30, 2024 Share #3 Posted June 30, 2024 Check this topic. https://www.l-camera-forum.com/topic/395665-hotshoe-springs-m11/#comment-5335621 1 Link to post Share on other sites More sharing options...
michaelbrenner Posted June 30, 2024 Author Share #4 Posted June 30, 2024 10 hours ago, kyono said: Check this topic. https://www.l-camera-forum.com/topic/395665-hotshoe-springs-m11/#comment-5335621 The tools are on the way! Link to post Share on other sites More sharing options...
michaelbrenner Posted June 30, 2024 Author Share #5 Posted June 30, 2024 Here is the post recommending the tools. Link to post Share on other sites More sharing options...
jakontil Posted July 4, 2024 Share #6 Posted July 4, 2024 On 6/30/2024 at 2:03 PM, erl said: Leica need to redesign the hot shoe. My M10 has the same issue. I have lost two EVF's as a direct consequence, at great expense to self. The same EVF's fit perfectly in my M6,7,8 and 9, but the M10 hot shoes is a design disaster. I have had Leica Service 'adjust' the springs but the result is pathetic. My solution is to insert a small piece of insulation tape to 'jam' the shoe when inserted. Most inelegant as a bit of engineering, but it works. Erl, evf is electronic viewfinder right? Or you mean the OVF? Link to post Share on other sites More sharing options...
erl Posted July 4, 2024 Share #7 Posted July 4, 2024 Advertisement (gone after registration) 12 hours ago, jakontil said: Erl, evf is electronic viewfinder right? Or you mean the OVF? Eek! Yes. Thank you for the correction. More accurately put: The Auxillary VF, as in it goes in the hot shoe. 1 Link to post Share on other sites More sharing options...
