wosamko Posted June 8, 2024 Share #1 Posted June 8, 2024 Advertisement (gone after registration) Hi Everyone, I hope you’re doing well, I see my JPEG photos are sharp on both Lightroom and ON1 but unfortunately DNG photos are not. any idea how to make DNG photos are sharp same as JPEG ? thanks Link to post Share on other sites More sharing options...
Advertisement Posted June 8, 2024 Posted June 8, 2024 Hi wosamko, Take a look here Sharpness between JPEG and DNG SL2 . I'm sure you'll find what you were looking for!
FlashGordonPhotography Posted June 8, 2024 Share #2 Posted June 8, 2024 What software are you using for the DNG files? Gordon Link to post Share on other sites More sharing options...
wosamko Posted June 8, 2024 Author Share #3 Posted June 8, 2024 1 minute ago, FlashGordonPhotography said: What software are you using for the DNG files? Gordon Hi Gordon, I use latest update for Adobe Lightroom wosam Link to post Share on other sites More sharing options...
jaapv Posted June 8, 2024 Share #4 Posted June 8, 2024 JPGs are sharpened in-camera, DNG conversions must be sharpened by the photographer during postprocessing (ON1); the sharpening level can be set in LR on export. Actually sharpening is quite a complicated subject, but best to master the basics first. Link to post Share on other sites More sharing options...
wosamko Posted June 8, 2024 Author Share #5 Posted June 8, 2024 2 minutes ago, jaapv said: JPGs are sharpened in-camera, DNG conversions must be sharpened by the photographer during postprocessing (ON1); the sharpening level can be set in LR on export. But I tried to make dng sharp as jpeg but I couldn’t . How to make same sharpness as in camera ? thanks Link to post Share on other sites More sharing options...
Jeff S Posted June 8, 2024 Share #6 Posted June 8, 2024 (edited) Sharpness can be a vague term. Of course LR has sharpening tools, but flat looking RAW/DNG files (common with high dynamic range files out of camera) can be adjusted to give the impression of increased sharpness using a variety of tools. These include contrast adjustments (using the tone curve or sliders),texture, dehaze, clarity, etc. One should learn the different ways these tools work, and their resulting effects. JPEG files are adjusted by someone else. Jeff Edited June 8, 2024 by Jeff S 1 Link to post Share on other sites More sharing options...
jaapv Posted June 8, 2024 Share #7 Posted June 8, 2024 Advertisement (gone after registration) That sounds like you need to study up a bit in postprocessing. https://www.adobe.com/creativecloud/photography/discover/image-sharpener.html And there are dozens of other tutorials out there. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted June 8, 2024 Share #8 Posted June 8, 2024 42 minutes ago, wosamko said: Hi Gordon, I use latest update for Adobe Lightroom wosam OK. Unfortunately there’s no real single, simple one click way to replicate all the things a camera has done to a jpeg. But basically it’s a mix of contrast, curves, clarity and sharpness sliders. A healthy dose of texture can help as well. Too much clarity and deglaze can look awful though. Try this as a *starting* point. Sharpness +40. Leave the other two sliders alone for now. Contrast and exposure: Move those around to optimise the histogram. Just fixing your white and black point can make a difference. Clarity +5 or so. Curves. Grab the middle of the curve and push it up a bit. That’ll open the file up for you, which is a common thing for camera jpegs to do. Now adjust texture to taste. And re adjust clarity, gently. Have a play with the detail slider in the sharpness module. See how you go from there. Play. You can always hit reset. Ideally you shouldn’t be trying to replicate a jpeg. It should look better. Otherwise just use the jpeg. Personally I find most modern jpegs too orientated to huge contrast and sharpness so they work on small screens. Looks awful in print. Gordon 4 1 Link to post Share on other sites More sharing options...
