hirohhhh Posted May 25, 2024 Share #1  Posted May 25, 2024 (edited) Advertisement (gone after registration) What is this black stain on the top of my roll? It shows on about half of the roll. Is it a light leak or something caused during development? I used MP and was shooting at f/16 for the entire roll.  The HP5+ was shot at 1600 and developed in DD-X for 13 minutes in JOBO tank. None of the shots are affected, just the top of the sprocket holes, and I just want to understand what it is. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 25, 2024 by hirohhhh Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/394928-mp-is-this-a-light-leak/?do=findComment&comment=5301796'>More sharing options...
Advertisement Posted May 25, 2024 Posted May 25, 2024 Hi hirohhhh, Take a look here MP: Is this a light leak?. I'm sure you'll find what you were looking for!
frame-it Posted May 25, 2024 Share #2 Â Posted May 25, 2024 this will help: Â https://beyondtheaperture.com/2019/11/diagnosing-light-edges-on-images-dark-edges-on-negatives/ Link to post Share on other sites More sharing options...
hirohhhh Posted May 25, 2024 Author Share #3 Â Posted May 25, 2024 47 minutes ago, frame-it said: this will help: Â https://beyondtheaperture.com/2019/11/diagnosing-light-edges-on-images-dark-edges-on-negatives/ Oh, thanks, yes, that helps a lot. I suspected it has something to do with the development, as these look like stains from the liquid rather than light leaks, so I'll eliminate leaks. Now I have to figure out what I'm doing wrong. I agitate for the first minute and then for 10 seconds every minute, same as I always do, and I normally don't see dark edges like in the example above. But I've noticed it happened a few times. I don't use the Paterson tank, so I don't have a swizzle stick; I just agitate. Not sure what else I can try with this Jobo tank. I have another metal tank that I never used because it always seemed complicated to load the roll, but I may give it a try, but I should be able to get the good results with the Jobo every time. Â Â Link to post Share on other sites More sharing options...
Siriusone59 Posted May 25, 2024 Share #4 Â Posted May 25, 2024 Maybe use just a bit more solution in the tank during development. Â Enough to keep the top reel completely submerged. Link to post Share on other sites More sharing options...
hirohhhh Posted May 25, 2024 Author Share #5  Posted May 25, 2024 4 minutes ago, Siriusone59 said: Maybe use just a bit more solution in the tank during development.  Enough to keep the top reel completely submerged. I used more than enough—500ml for one roll. Link to post Share on other sites More sharing options...
250swb Posted May 25, 2024 Share #6  Posted May 25, 2024 (edited) 3 hours ago, hirohhhh said: I used more than enough—500ml for one roll. You can see your ILFORD HP5 edge markings are fully developed so you've used enough developer but maybe not enough fixer. You also need to agitate the fix. Edited May 25, 2024 by 250swb Link to post Share on other sites More sharing options...
hirohhhh Posted May 25, 2024 Author Share #7  Posted May 25, 2024 (edited) Advertisement (gone after registration) 3 hours ago, 250swb said: You can see your ILFORD HP5 edge markings are fully developed so you've used enough developer but maybe not enough fixer. You also need to agitate the fix. Same—I used 500 ml of developer, stopper, and fixer. Also, wash it thoroughly between each solution and for 10 minutes in running water at the end. One thing that came to mind: Sometimes I insert the roll in the reel against the curl. Usually, I don't, but since I'm doing this in the dark, if I start it that way, I just continue. I thought it didn't matter, but maybe that causes the film to get stuck so the developer (or fixer) cannot reach the edges enough. I clearly remember I did that to this roll. Edited May 25, 2024 by hirohhhh 2 Link to post Share on other sites More sharing options...
hansvons Posted May 25, 2024 Share #8 Â Posted May 25, 2024 59 minutes ago, hirohhhh said: One thing that came to mind: Sometimes I insert the roll in the reel against the curl. Good explanation. Link to post Share on other sites More sharing options...
