Larsy Posted May 16, 2024 Share #1  Posted May 16, 2024 Advertisement (gone after registration) Hey Everyone, Ive been building a set of Leica Rs for 9 months or so and am loving these lenses for cinematography. However I have run into an issue with the aperture of my 50mm summicron. The aperture is stuck at F2. When I turn the aperture ring, nothing happens. For awhile leading up to this issue I noticed that there were times the aperture was not working when I tried to open up or stop down, but with a few turns it would eventually engage and work as intended. Now however it wont change at all. Its still usable but using a broken lens wont cut it for a lot of the work that I do. Is this a common issue and is there a way to fix myself? If I had to send it out I might just buy a Summilux. Any tips from anyone who dealt with a similar issue? Link to post Share on other sites More sharing options...
Advertisement Posted May 16, 2024 Posted May 16, 2024 Hi Larsy, Take a look here Leica R 50mm Summicron Broken Aperture. I'm sure you'll find what you were looking for!
spydrxx Posted May 16, 2024 Share #2  Posted May 16, 2024 I'd call either DAG (Don Goldberg) or Sherrie Krauter to fix the frozen diaphagm. Link to post Share on other sites More sharing options...
Larsy Posted May 19, 2024 Author Share #3  Posted May 19, 2024 Thanks. Was hoping it was common and or easily fixable. Ive seen those two mentioned around quite a bit. Looks like Ill have to reach out. Link to post Share on other sites More sharing options...
250swb Posted May 19, 2024 Share #4  Posted May 19, 2024 On 5/16/2024 at 8:45 PM, Larsy said: Hey Everyone, Ive been building a set of Leica Rs for 9 months or so and am loving these lenses for cinematography. However I have run into an issue with the aperture of my 50mm summicron. The aperture is stuck at F2. When I turn the aperture ring, nothing happens. For awhile leading up to this issue I noticed that there were times the aperture was not working when I tried to open up or stop down, but with a few turns it would eventually engage and work as intended. Now however it wont change at all. Its still usable but using a broken lens wont cut it for a lot of the work that I do. Is this a common issue and is there a way to fix myself? If I had to send it out I might just buy a Summilux. Any tips from anyone who dealt with a similar issue? Try exercising the stop-down lever on the back of the lens and see if you can get it to free up. Link to post Share on other sites More sharing options...
nitroplait Posted May 19, 2024 Share #5 Â Posted May 19, 2024 It may be hardened oil on the aperture blades. My R 50mm Summicron (v1) hand to be cleaned recently for that reason. Link to post Share on other sites More sharing options...
Larsy Posted May 20, 2024 Author Share #6  Posted May 20, 2024 5 hours ago, 250swb said: Try exercising the stop-down lever on the back of the lens and see if you can get it to free up. Well Ill be damned. I did this and it works again. For how long? Who knows. Thanks for the tip! Link to post Share on other sites More sharing options...
hepcat Posted May 20, 2024 Share #7  Posted May 20, 2024 Advertisement (gone after registration) 1 hour ago, Larsy said: Well Ill be damned. I did this and it works again. For how long? Who knows. Thanks for the tip! Definitely sounds like oil on the aperture blades. It needs a cleaning. Link to post Share on other sites More sharing options...
