sandro Posted April 11, 2024 Share #1  Posted April 11, 2024 Advertisement (gone after registration) A friend showed me this magnifier this afternoon, which I believe is a magnifier LOOFV, to be used on a focusing stage. In the same collection I only saw a OORES focusing stage, but I am not sure if it fits on that one. Does anyone know with which focusing stage the magnifier LOOFV was to be used? Lex Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/392704-magnifier/?do=findComment&comment=5182286'>More sharing options...
Advertisement Posted April 11, 2024 Posted April 11, 2024 Hi sandro, Take a look here Magnifier. I'm sure you'll find what you were looking for!
romanus53 Posted April 12, 2024 Share #2  Posted April 12, 2024 Hello Lex, first versions of FULDY and OORES use loupes that slide into a half-moon-shaped mounting, later versions use the bayonette your loup shoes (with four wings). Although your loupe is one of the early fat type. The changes may be made around 1933 I think but other my know better. I have the later versions of OORES for two lenses with these mountings and two FULDY and can provide some pictures if needed (had to made them still 😉 ) 1 Link to post Share on other sites More sharing options...
jc_braconi Posted April 12, 2024 Share #3  Posted April 12, 2024 Hello, there is a 90° version name is LOOGI on the book from Mr BUTKUS but on the box it is write LKIOO  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/392704-magnifier/?do=findComment&comment=5183486'>More sharing options...
jc_braconi Posted April 12, 2024 Share #4  Posted April 12, 2024 You can find some OORES and FULDY here Reproduction devices 2 Link to post Share on other sites More sharing options...
alan mcfall Posted April 13, 2024 Share #5  Posted April 13, 2024 (edited)  Here are a few of these "fat" 5x viewers. Used on VEHIG, OORES, PLOOT, focoslide, universal copying device and others. Early versions were slide-in, first completely round lip, then lip with small flat or D shape, then it seems Leitz decided that it would be more secure to use a bayonet version. The code changed from LOOFV to LVFOO. A similar code changed for the chimney, and right angle viewers, e.g. LOOGI to LKIOO. The fat viewer had a sliding focus at the bottom, the others at the top. For the LVFOO only, the bottom would rotate when locking or unlocking the bayonet, so a small screw and slot were added as can be seen in the photos, below the logo. The OORES transitioned from slide in to bayonet, as did the FULDY, but I believe the VEHIG was discontinued before the bayonet arrival, and all that I have seen are slide in. As the early PLOOT's used a screw in magnifier and then moved to the bayonet, I don't believe any of the early slide in viewers can be used with the PLOOT. The PAMOO replaced the LKIOO (prism vs. mirror) but you could still use it with the VISO I.   Edited April 13, 2024 by alan mcfall photos 1 Link to post Share on other sites More sharing options...
sandro Posted April 15, 2024 Author Share #6  Posted April 15, 2024 On 4/12/2024 at 7:01 AM, romanus53 said: Hello Lex, first versions of FULDY and OORES use loupes that slide into a half-moon-shaped mounting, later versions use the bayonette your loup shoes (with four wings). Although your loupe is one of the early fat type. The changes may be made around 1933 I think but other my know better. I have the later versions of OORES for two lenses with these mountings and two FULDY and can provide some pictures if needed (had to made them still 😉 ) When you feel like taking pictures that might be helpful, Romanus. Lex Link to post Share on other sites More sharing options...
sandro Posted April 15, 2024 Author Share #7 Â Posted April 15, 2024 Advertisement (gone after registration) Alan, the photos don't show when I click on them. Lex Link to post Share on other sites More sharing options...
romanus53 Posted April 15, 2024 Share #8  Posted April 15, 2024 OORES 2nd version for two lenses with either slip-in- or bayonett-mount for the magnifying loupe Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! also slight differences in the cut-out for the long-times-dial 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! also slight differences in the cut-out for the long-times-dial ' data-webShareUrl='https://www.l-camera-forum.com/topic/392704-magnifier/?do=findComment&comment=5189852'>More sharing options...
romanus53 Posted April 15, 2024 Share #9  Posted April 15, 2024 FULDY with different mounts for the loupe or without/missing on the right Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! the early versions had a screw-in-ring to mount the camera body, both with cut-out for long-times-dial 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! the early versions had a screw-in-ring to mount the camera body, both with cut-out for long-times-dial ' data-webShareUrl='https://www.l-camera-forum.com/topic/392704-magnifier/?do=findComment&comment=5189854'>More sharing options...
alan mcfall Posted April 16, 2024 Share #10 Â Posted April 16, 2024 Having some trouble with photos and my computer. Here is another attempt at the photos. Â Â Â Â Link to post Share on other sites More sharing options...
sandro Posted April 16, 2024 Author Share #11 Â Posted April 16, 2024 Perhaps there's a problem on my side, but I still can't see the photos, Alan. Romanus, thanks a lot, your images help me to understand a few things. Like so often with Leitz equipment: once you understand it things seem relatively easy, but it takes some effort to there in the first place. Lex Link to post Share on other sites More sharing options...
