Aryel Posted April 10, 2024 Share #1  Posted April 10, 2024 (edited) Advertisement (gone after registration) Hello, I just got a new flash (Godox Lux Senior) to use with my M and iiif camera. From the user manual, it seems that I should use either: 1/ red scale set to 0 with 1/25 shutter speed or 2/ red scale set to 20 with 1/50th shutter speed. Can anyone confirm that this is correct? The flash fires so the cable connection is working. Thanks a lot! Edited April 10, 2024 by Aryel Link to post Share on other sites More sharing options...
Advertisement Posted April 10, 2024 Posted April 10, 2024 Hi Aryel, Take a look here iiif redscale flash settings. I'm sure you'll find what you were looking for!
jankap Posted April 10, 2024 Share #2  Posted April 10, 2024 (edited) I suppose your flash is an electronic one (not with bulbs). My manual says, that one can use scale 0 (zero) up to 1/25sec and scale 20 for 1/50sec. The point is, that electronic flash gives an instantaneous and a very short flash, so both curtains must be open as the flash comes. The other contacts were for the various brands of flashbulbs. They needed a start-up time and burned longer. Edited April 10, 2024 by jankap 1 Link to post Share on other sites More sharing options...
jankap Posted April 10, 2024 Share #3  Posted April 10, 2024 Caution. If the flash is of an older type, it can/will burn the transistor of the flash contact of an electronic camera. The IIIf is safe of course, no transistors inside.😉 1 Link to post Share on other sites More sharing options...
roydonian Posted April 10, 2024 Share #4 Â Posted April 10, 2024 Older is only a couple of decades ago. An electronic flash unit purchased from Jessops in the early 1990s burned out the synchronisation of my then-recently-purchased Digilux. 1 Link to post Share on other sites More sharing options...
Pyrogallol Posted April 10, 2024 Share #5 Â Posted April 10, 2024 Yes. Quite often people giving away old film cameras, usually their late parents, include flash guns with the cameras. If they are passed on to other camera club members they are warned about using them on modern cameras. 1 Link to post Share on other sites More sharing options...
