Hello,
I currently own a Leica SL and I'm using this camera with M lenses (Summilux 35 FLE, and Noctilux f1).
I would like to buy a used Leica M11 (or M10R) and I would like to know if I could still enjoy my old Noctilux f1 with it, or will I have very bad results? (in that case, I'll go with a M10).
Thank you very much for your help.
x
What makes you think the results wouldn't be good? The lens was made for the M platform after all.
What makes you think the results would be better with the M10?
Just trying to understand what your concerns are...
I was thinking that older lenses had less good results with higher resolution sensors. But maybe I am wrong ?
I fear you are 😎. The M11 works perfectly with my couple of dozen M and LTM lenses including symmetrical ones like S-A 21/3.4 from 1977 (1st pic) and even earlier ones like Elmar 35/3.5 from 1948 (2nd pic).
Fear not. As a 'heavy user' of vintage glass, I'd say that advances in sensor technology have only brought more usability to old lenses - mostly due to improved dynamic range. If you think about it, a sensor just captures the image that it "sees". It doesn't know what sort of glass the light has travelled through. In other words, sensors may respond differently (think M9 vs M11 colours), but they are effectively "lens agnostic". Higher resolution sensors will only allow you to zoom in further and better see the flaws of the lens, which have always been present irrespective of whether it's a modern or a vintage one.
FWIW, I have yet to mount a Noctilux on my M11, but when I do, I fully expect it to perform at least as well as on the M10...
Edited by Ecar
On 3/17/2024 at 5:45 PM, Mikewest said:
Hello,
On the M11, wide open at f1, there is some blooming/ghosting. I suggest -3/4EV or -1EV to compensate. Overall performance is still excellent and the lens fingerprint remains unique
The Noctilux f1 looks great on the M11 if you respect its limitations. Closer subjects tend to look better if you're shooting at wide apertures. And the lens is soft, even when focus is perfect, unlike the f0.95. E.g.:
Environmental shots take on an otherworldly glow that is kinda fun but ultimately a bit limiting. And yeah, there's lots of fringing
Edited by Jeremy Bunting
  • 2 months later...
On 3/17/2024 at 12:45 PM, Mikewest said:
Hello,
No problem OP. Go to a camera store and try it out for yourself before the investment.
You'll be pretty happy how the F1 performs ...
(Almost) wide open
Closed a bit
As a Noctilux f/1.0 owner, this is what I would have expected.
I have M lenses from the early M days all the way thru modern lenses. They all look great on my M11. The 50 f2 summitar was great and it's LTM! Having the resolution is great if you want a 6' enlargement 🙂 and it doesnt take a 2023 summilux to get there either!
On 5/25/2024 at 12:19 PM, BlackCrowFoto said:
Maybe sacrilegious here, but some of the sharpest, smoothest results I got from the M11M have been with a $50 Helios lens, the 58/2.
No problem for the camera or the lens.
Any Leica glass will offer similar or better results, I'm sure.
I have the1st gen voigtlander 50 f1.5 LTM (nokton) and comparing it so posted raw files from lenses costing 10X more it holds its own in sharpness, flare and bokeh! I would say the same for my old canon LTM 35 f2.8 (late model) - very capable lens! maybe you if crop at 200% you might spot some differences but not in real world use! Having said that I would love to own a summilux 50 🙂 Pixel peepers are never happy it seem today!
