4 hours ago, Carlos cruz said:
Haven’t heard of any app to fix corners, I am using superangulon on m10 and the best you can do is to convert it to bw or just live with it until you reach your pc
It’s easy on the desktop, just hoping to find a mobile solution. Thanks
4 hours ago, Al Brown said:
A well known corner fixing manual lens profile to be dialed in while shooting is the 11134 for Elmarit-M 2,8/21mm. Try it and report.
The corners with made-for-film wide angles and UWAs improve drastically with M10 series and upwards. Not much help but a cool tip.
I’ll give it a try, thanks
You might have a look at Adobe flat field correction: https://helpx.adobe.com/lightroom-classic/help/flat-field-correction.html
You will have do some testing to achieve the right file for calibration. Though if you succeed with it the results are good. At least they are with my 21mm Super-Angulon which is one of the worst lenses for color shift.
Thanks. I'm sure it works great, but I don't see any way to apply on the iOS app. Are you aware of any way?? Thanks
  • 1 month later...
