Radek71 Posted March 2, 2024 Share #1 Posted March 2, 2024 Advertisement (gone after registration) Hi everbody, I have a problem with my leica d-lux type 109. I mean playmode funkction. Whenever pushing playmode button function or trying to set on playmode function in menu start, leica is going to freeze. Just every button is blocked, I must take off&on the battery to restart. Anybody know what is the issue? Link to post Share on other sites More sharing options...
Advertisement Posted March 2, 2024 Posted March 2, 2024 Hi Radek71, Take a look here Leica 109 playback issue. I'm sure you'll find what you were looking for!
stuny Posted March 2, 2024 Share #2 Posted March 2, 2024 No idea, but I'm commenting just to move your post to the top of the page. Link to post Share on other sites More sharing options...
Radek71 Posted March 2, 2024 Author Share #3 Posted March 2, 2024 Thank You Link to post Share on other sites More sharing options...
wda Posted March 2, 2024 Share #4 Posted March 2, 2024 It might respond to a factory restart. Or a fresh battery. Link to post Share on other sites More sharing options...
Radek71 Posted March 2, 2024 Author Share #5 Posted March 2, 2024 Battery are in quite good condition. What u mean factory restart? Is it sth different than Leica Reset in Setup Settings? Link to post Share on other sites More sharing options...
wda Posted March 2, 2024 Share #6 Posted March 2, 2024 My mistake. I meant reset which you will find in menu/settings. Link to post Share on other sites More sharing options...
Radek71 Posted March 2, 2024 Author Share #7 Posted March 2, 2024 Advertisement (gone after registration) Ok, reset doesn't work unfortunately:( I think it might be sth with firmware. But there is no new firmware since ver 1.0 for 109 type, so I can't upgrade it and fix it. Link to post Share on other sites More sharing options...
wda Posted March 2, 2024 Share #8 Posted March 2, 2024 At least you can use your camera. You could ask Leica! There might be be a local repair technician. It probably just needs cleaning. Try brushing around the buttons and a blower or small vacuum cleaner. Link to post Share on other sites More sharing options...
Radek71 Posted March 2, 2024 Author Share #9 Posted March 2, 2024 I did it. Its no a problem in specific button (and dust around) but with playmode itself. Playmode in menu section is also freezing camera. I mean - if Im trying to enter this option. Every another button and option are working good&properly. 1 Link to post Share on other sites More sharing options...
mujk Posted March 2, 2024 Share #10 Posted March 2, 2024 Did you try a different SD card and/or reformatting the card? Link to post Share on other sites More sharing options...
Radek71 Posted March 2, 2024 Author Share #11 Posted March 2, 2024 I have two cards SD, both were formated several times. At the picture below u will see the problem - anytime I try to jump into section on the right, camera is freezing Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/390212-leica-109-playback-issue/?do=findComment&comment=5067465'>More sharing options...
Krusty Posted April 1, 2024 Share #12 Posted April 1, 2024 I also have a DLUX Typ 109 with the SAME issue. I already did the factory reset and it did not help. It also happens when you have no SD Card inserted. That means: Pressing the Play Button with no SD Card brings the Camera to a freeze and i have to Remove the Battery. So i think that the SD Card is not related to this issue… Firmware is 1.0 and as far as i know there is no other firmware available…. Any Ideas? Link to post Share on other sites More sharing options...
Krusty Posted April 1, 2024 Share #13 Posted April 1, 2024 vor einer Stunde schrieb Krusty: I also have a DLUX Typ 109 with the SAME issue. I already did the factory reset and it did not help. It also happens when you have no SD Card inserted. That means: Pressing the Play Button with no SD Card brings the Camera to a freeze and i have to Remove the Battery. So i think that the SD Card is not related to this issue… Firmware is 1.0 and as far as i know there is no other firmware available…. Any Ideas? Edit: my problem happens when I press the play button ) Link to post Share on other sites More sharing options...
Krusty Posted April 1, 2024 Share #14 Posted April 1, 2024 vor 4 Stunden schrieb Krusty: Edit: my problem happens when I press the play button ) I have again to edit my post: I also have the crash / freeze as soon as I enter the playback menu…. it seems to be a very rare issue as there are not many posts regarding this issue. Does anybody know a way how to install the app on the 1.0 firmware again? So that it has a clean install? Link to post Share on other sites More sharing options...
