There are a few businesses offering the service with varying succes, there are a few YouTube reports that show this and has been discussed on this forum (use the  search function).Uncharted waters. But basically there is nothing to lose
11 hours ago, Jess75 said:
HI everyone. Does anyone have experience with buying ICF glass coated low pass filter for Leica M9 camera on AliExpress?
Is it a feasible solution? Thanks for the replies.
I would only do this if the sensor is really unusable for you. There is a degree of corrosion that is not visible when using lenses wide open. Once you start the 'operation' there is no way back. If it fails you end up with a dead sensor that is beyond repair.
Even the professionals have accidents occasionally. I saw a few dead M9s on ebay. Of course they pay back the fee for the repair but bottom line is that your M9 is only good for parts after that.
Edited by dpitt
  • 4 weeks later...
i have / had the same problem with the corroded sensor, and i thought about to sell it for less or to repair. At that time i was scanning my slides and negatives with a professional scanner that is producing raw files. For this action i bought Silverfast HDR 9. This Software reduces and eliminates scratches and dust. I thought about trying out this software with my corroded files from the M9 --- it is MIND BLOWING!!! There´s nothing left from dots or anything else thats on the original. The Price of the software is about 250,-€. The homepage of Silverfast: https://www.silverfast.com/   ( i don´t get any money!!!!! ) You can Download a trial, but take the studio edition ( the expensive one ), install it and you will use your m9 without any doubt and any fear of  bad results. It´s amazing. At the end it´s just one more step in our workflow but even better than to invest in a suspicious service. In the link the guy is talking about scanning - replace the scanner with the m9 - and you know what he is talking about. https://www.youtube.com/watch?v=umXH39GlUkM.  In our case it is much more easier because our corroded spots are always at the same place, so once you have your settings you don´t have to change anything. I guess this is the easiest way to get along with Leica M9´s problem - for me.
yours Kumpel
AFAIK the original M9 cover glass includes IR and UV filters, but there is no anti-aliasing filter. So any replacement would need to match this setup. Companies doing these replacements seem to offer at least some information on the glass they use.
  • 2 weeks later...
