Pelu2010 Posted November 26, 2024 Share #41 Posted November 26, 2024 Advertisement (gone after registration) On 3/7/2024 at 9:14 PM, MindsEye said: @Pelu2010, I don't know the European distributor but when I emailed LLL ( lightlenslabna@gmail.com ) they were responsive. Perhaps they can assist you. I verified with Tony at PopFlash that ALL of the Light Lens Lab L-M adapters have the misalignment issue I posted here. So I need to send mine back until replacements are available. Allegedly that will be the end of this month. Hope you are able to get one- from the new batch. Hi, I was able to get one without missalignment. I am using it on the SL2-s. It works perfect and is much fun. It took LLL 3 Month to deliver the adapter. Many of my Leica lenses are now macro lenses too. And some of the adapter Nikon and Olympus Lenses also benefit from the minimal focus distance. I would love if we could get a M to M adapter with this helicoid. Like a macro helicoid. In the end the Leica Q does the same trick. It's a helicoid inside of the lens. cheers Peter and thanks Link to post Share on other sites More sharing options...
Advertisement Posted November 26, 2024 Posted November 26, 2024 Hi Pelu2010, Take a look here Fabulous M-L adapter from Light Lens Lab. I'm sure you'll find what you were looking for!
Stuart Richardson Posted November 27, 2024 Share #42 Posted November 27, 2024 (edited) On 11/26/2024 at 9:36 AM, Pelu2010 said: Hi, I was able to get one without missalignment. I am using it on the SL2-s. It works perfect and is much fun. It took LLL 3 Month to deliver the adapter. Many of my Leica lenses are now macro lenses too. And some of the adapter Nikon and Olympus Lenses also benefit from the minimal focus distance. I would love if we could get a M to M adapter with this helicoid. Like a macro helicoid. In the end the Leica Q does the same trick. It's a helicoid inside of the lens. cheers Peter and thanks The challenge with that is that you need some space to build the adapter, so the thickness of the adapter will already push your focus closer by that amount. What you wind up building is a focusing extension tube, not an adapter. So while you gain close focus, you give up focusing to infinity. How close to infinity you can focus will depend on the thickness of the adapter and the focal length, but ultimately it is not a super practical solution. Leica has tried to address this by introducing closer focusing versions of their lenses, but that is obviously a very expensive solution. If you must focus closer than the lens allows with M lenses, the most practical solution is one of these helicoid adapters on an L mount camera because the shorter base length of the sensor to the mount allows for the thickness required to build an adapter with a helicoid that also can focus to infinity. You need an EVF or live view to focus anyway, as the RF uncouples around .7m. Edited November 27, 2024 by Stuart Richardson Link to post Share on other sites More sharing options...
mikozia Posted November 29, 2024 Share #43 Posted November 29, 2024 Kipon makes an excellent TL to M adapter with a built-in close up focus helicoid. I have been using it for quite some time. 1 Link to post Share on other sites More sharing options...
Dr. G Posted December 6, 2024 Share #44 Posted December 6, 2024 On 11/27/2024 at 4:47 AM, Stuart Richardson said: The challenge with that is that you need some space to build the adapter, so the thickness of the adapter will already push your focus closer by that amount. What you wind up building is a focusing extension tube, not an adapter. So while you gain close focus, you give up focusing to infinity. How close to infinity you can focus will depend on the thickness of the adapter and the focal length, but ultimately it is not a super practical solution. Leica has tried to address this by introducing closer focusing versions of their lenses, but that is obviously a very expensive solution. If you must focus closer than the lens allows with M lenses, the most practical solution is one of these helicoid adapters on an L mount camera because the shorter base length of the sensor to the mount allows for the thickness required to build an adapter with a helicoid that also can focus to infinity. You need an EVF or live view to focus anyway, as the RF uncouples around .7m. Apparently the LLL adapter will focus to infinity at the expense of the nearer end of the close focus range. Other helicoids sacrifice infinity focusing for getting closer. Link to post Share on other sites More sharing options...
chris_tribble Posted December 6, 2024 Share #45 Posted December 6, 2024 Well - just received my LLL Helicoid Adapter and I'm delighted. It's beautifully made and smooth as silk. It also pairs interestingly with my close focus 50 Lux on the SL2. We're not in macro territory, but it does make it possible to focus on detail in ways which would not be possible with the one lens. Examples below. A grey day in Cumbria. The office window looks up to Shap (one of the highest passes on the Pennines in Northern England for those who don't know it. Conclusion - the LLL M to L adapter is a useful little device which makes M lenses even more useful on L mount. Standard 0.7 distance Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Close 0.45 distance LLL Adapter at max extension Infinity (with the adapter - and through a window...) 100% crop 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Close 0.45 distance LLL Adapter at max extension Infinity (with the adapter - and through a window...) 100% crop ' data-webShareUrl='https://www.l-camera-forum.com/topic/389164-fabulous-m-l-adapter-from-light-lens-lab/?do=findComment&comment=5718802'>More sharing options...
chris_tribble Posted December 6, 2024 Share #46 Posted December 6, 2024 Add an ELPRO 3 and you really are moving towards a useable macro. If the Lumix 100 is 1:1, the 50 Luc close focus + LLL + ELPRO is getting close to 1:2. Useful to have in the bag. The SL2 + 50 is a nice walk around set up. The LLL is a real world enhancement of this if you want to pick out detail, and the ELPRO can always be in a pocket! I'm aware that WB is all over the place - I was just concentrating on focusing... ALSO - n.b. different OOF areas are related to the variable curvature of the CD cover. Summilux 50 Lux close focus + LLL with ELPRO 3 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Lumix 100 f2.8 Macro Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Lumix 100 f2.8 Macro ' data-webShareUrl='https://www.l-camera-forum.com/topic/389164-fabulous-m-l-adapter-from-light-lens-lab/?do=findComment&comment=5718814'>More sharing options...
chris_tribble Posted December 6, 2024 Share #47 Posted December 6, 2024 (edited) Advertisement (gone after registration) And of course if you really want to, using the 35mm Fotiodiox Macro Tube can take you to truly silly places... 50 Lux CF + LLL + 35mm Extension Tube Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Lumix 100 f2.8 Macro + Fotodiox 35mm Extension Tube Edited December 6, 2024 by chris_tribble Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Lumix 100 f2.8 Macro + Fotodiox 35mm Extension Tube ' data-webShareUrl='https://www.l-camera-forum.com/topic/389164-fabulous-m-l-adapter-from-light-lens-lab/?do=findComment&comment=5718821'>More sharing options...
