Pierre68 Posted February 7, 2024 Share #61  Posted February 7, 2024 Advertisement (gone after registration) 2 hours ago, Seba66 said: to think in the morning which lens I will use that day, according to the program This is the way to go when using fixed focal lenses. I have found out that I was taking better pictures when walking in the wood around my house with just one fixed focal than the using one of the awesome Leicas 16-35 or 24-90 VE... I realized that my framing were more interesting when using the fixed focal, no matter which focal it was. 2 Link to post Share on other sites More sharing options...
Advertisement Posted February 7, 2024 Posted February 7, 2024 Hi Pierre68, Take a look here Advice on camera/lens for trekking to Everest Base Camp. I'm sure you'll find what you were looking for!
burchyk Posted February 7, 2024 Share #62 Â Posted February 7, 2024 Voigtlander 90 APO is a great choice. Great optics, small and light. That plus a compact 28mm would be my choice. Skip the 35-50. 1 Link to post Share on other sites More sharing options...
henning Posted February 8, 2024 Share #63  Posted February 8, 2024 (edited) I haven't read the whole thread, so some of what I'm saying will likely already have been mentioned (and/or refuted). In the mid 90's we trekked around Annapurna for 3 weeks. We had a full support crew for tents, cooking etc., but I carried all photo gear at all times. These were film days, so a lot of bulk and weight were dedicated to film. I took 2 M6's with 21, 35, 50 and 90mm lenses as well as a Noblex 150 and a Mamiya 6 with 3 lenses, tripod and light meter, etc. Lots of stuff. I took lots of photos and don't really regret taking all that stuff. I used the 21 relatively seldom, it was probably the least used item. The Noblex was much better suited for the wide views. I used the 35 the most, just like for most of my life for personal photography and the 90 next. We climbed as high as 5000m, but on the way, as one of the locals said, every day it's 'a little bit up and a little bit down'. Usually meaning it was about 1000m+ up a steep path, then down a 1000m+ steep path. Nothing was flat, and the 1000m up and down happened multiple times many days. After the first day I regretted everything; the weight as well as the whole trip. The next day was better and after three days it was all fantastic, as I was acclimatized by then and had no trouble with the strenuous pace or the altitude. Now, of course I would take different gear. In your case, I would add a small 90, preferably the Macro-Elmar but the next best would be the App-Skopar. Their performance is surprisingly fairly similar but the Macro-E is smaller and can focus closer. Get and take extra batteries; the M10 batteries don't last that long. I don't know how good your recharging opportunities will be. The camera will be fine in -20 or even -40C° weather, as long as you can tuck it under a top layer between shooting opportunities to keep blowing snow off it. Try not to bring it directly into a warm space in one go; moisture will condense and freeze on various parts and make it inoperable for a while. I've shot quite a bit in -40° weather with Leicas since the 60's, including digital M8, M9, M240 and M10 and all worked fine when used continuously in the cold for up to an hour. After that I warmed them up (slowly). Film was tricky, as it got brittle and cameras could tear it at the sprocket holes, and rewinding could be an issue. Larger formats had more and different issues. Edited February 8, 2024 by henning 1 Link to post Share on other sites More sharing options...
Xavier Posted February 8, 2024 Share #64 Â Posted February 8, 2024 As I look through the comments on weather sealing / not changing lenses too much, etc, I wanted to add a couple of things. None of my three trekkings in Nepal was very harsh on gear. Of course it is important to use a bag that protects everything well (from constant motion and occasional rain/snow), but wind blowing dust was very rare so lens changes were not a problem at all. Even on high passes or ridges, I could just turn my back to the wind and change the camera without any real dust concern. Obviously, I would not have the camera out in storms, or very rarely and cautiously slow, but this is just common practice anyway. As far as I remember, the main (and only real) issue with cameras was the cold temperature reducing battery life a lot... 2 Link to post Share on other sites More sharing options...
thrid Posted February 9, 2024 Share #65 Â Posted February 9, 2024 (edited) Tri-Elmar 28-35-50. It's f4, but would cut down significantly on exposing the sensor to dirt and moisture due to lens changes. It's also a lot safer to change focal lengths on the Tri-Elmar, than juggling lenses, while hanging off the side of a mountain... Summicron-M 35 or 50 as your fast lenses. More compact and less weight than the Lux. You can always go up one asa to make up for F2 vs F1.4 The old Macro-Elmar(APO) 90 is very compact and super sharp, but it is collapsible. Use a hood with this one. I think these are selling relatively cheaply these days. The Voigtlander APO 90's are very, very good and may be lighter than the Leica equivalent. (certainly cheaper) Extra batteries due to the cold. Maybe you can take a power bank, that you can keep warm in your jacket and use a USB-C cable to charge the camera in a pinch Sounds like a fantastic trip. Be safe and good luck. Â Edited February 9, 2024 by thrid 1 Link to post Share on other sites More sharing options...
shobita neupane Posted April 3, 2024 Share #66 Â Posted April 3, 2024 Did you make the decision yet? Link to post Share on other sites More sharing options...
burchyk Posted April 3, 2024 Share #67 Â Posted April 3, 2024 Advertisement (gone after registration) waiting for those amazing pictures! Link to post Share on other sites More sharing options...
Seba66 Posted April 4, 2024 Author Share #68  Posted April 4, 2024 On 4/3/2024 at 11:37 AM, shobita neupane said: Did you make the decision yet? Thank you for your interest. I decided on the kit of three lenses, 28-50-90, all M. For the body I am still undecided between M10 and SL2-S, weight and lightness against the possibility of charging on the go with a power bank and an USB cable.  Honestly I have to say that I have another thought in the back of my mind. I just got back from a trip to the Philippines where I took 99% of the photos with SL2-S and my new 35 SL APO. Well yes, overwhelmed by the results... But I think in the end I will resist this new temptation for a better portability 1 Link to post Share on other sites More sharing options...
DrM Posted April 4, 2024 Share #69  Posted April 4, 2024 My 2c.. if you have the money I would buy the 24-70 and use it with the SL2s (~1800g), ok weather sealing, IBIS, no lens swap-no dust, video (why not, if you are in the neighbourhood). The M option for me, M11, 21SEM and 50lux/cron, the resolution allows good cropping (21mm => 27.3mm(1.3x/36mp) => 37.8mm (1.8x/18mp) ; 50mm => 65mm (1.3x/36mp) => 90mm (1.8x18mp)), compact, good battery, low weight (M11:530g;21SEM 279g; 50cron 240g; total 1049g) Enjoy the trip. Best Marc  1 Link to post Share on other sites More sharing options...
