Hello everybody,
I just came across the website of ARRI (for those of you who don't know: it's a big cinema camera, lens and light manufacturer from Germany). They build the Arri Alexa camera as a monochrom version, which I guess is similar in sensor design as Leica does for photography (increased resolution, higher dynamic range, more light sensitive...).
One thing I can't find anywhere is: do the Leica monochrom cameras also have no IR filter and that's the reason why they render highlights and shadows in a different way? In all the reviews out there, no one is talking about that point specifically.
Here's the link to the ARRI website:
https://www.arrirental.com/en/cameras/exclusive-cameras/alexa-monochrome-cameras
x
That is incorrect. The M cameras do have an IR filter. However the effectiveness is between 70 and 85% varying by model due to technical reasons. This makes the camera suitable for limited IR use but it is by no means comparable to true IR enabled cameras.
  • 1 month later...
It can be done, M246 Heliopan filter
Hi, Heliopan 695. They make a range of 3 IR filters. Worth checking out on the web. You may need a tripod for the denser IR filters and shoot at high ISO. This one at 3200. Obviously a bright sunny day is best. If you can focus with live view that's best.
Cheers!
  • 5 months later...
On 3/7/2024 at 11:41 AM, overexposed said:
i once sent an inquiry to leica, to check if they are willing to convert an M10M to full spectrum, unfortunately they declined :(
kolarivision dot com
does these changes, also replaces the hot pass filter of those that have oxidized it
in my first post LINK I asked if anyone has done this
Thanks. Toni
