Which 1:1 Macro extender for 60mm Elmarit-R Rom?
I am looking for a 1:1 extender for a 60mm Elmarit-R Rom. Do I need the 14299 the one with Rom contacts? I haven’t found any information whether the older one the 14198 will mount. I plan to use the combination on an M10M using a 6 bit coded R to M adapter.
If you want to use the 60mm Macro-Elmarit-R with an adapter for the M10 (or any other M camera with Liveview) the ROM contacts don't matter. There is no direct connection between the lens and the camera. Automatic diaphragm won't work and you don't need it as the Liveview picture is bright enough even if you stop down to f/16. You can chose correction for the lens manually in the camera's menu, but nothing else is necessary (and I think that even this "correction" isn't necessary if you don't think that seeing your lenses data in the EXIF is essential). So you can use any Macro-Adapter-R. I use the old Macro-Adapter-R 14256 and I get 1:1 with it.
