lecycliste Posted July 23, 2024 Share #21 Posted July 23, 2024 Advertisement (gone after registration) Yes, the RRS L-bracket with grip is a good way to go IF: - You're NOT using a 35mm f/2 RF Summicron. Unlike the RRS L-bracket and grip for the M10-R, the bracket and grip for the M11 lacks the cutout in the grip that lets you just twist on the 35/2 RF Summicron. You need to remove the grip to mount the goggled lens. - You're NOT using the 135mm f/2.8 Elmarit-M. This goggled lens has the same problem - the L-bracket / grip has to come off to mount it. . Link to post Share on other sites More sharing options...
Advertisement Posted July 23, 2024 Posted July 23, 2024 Hi lecycliste, Take a look here L-bracket . I'm sure you'll find what you were looking for!
Jon Warwick Posted April 22 Share #22 Posted April 22 (edited) For those of you that specifically have the RRS bracket for the M11, how tightly fitting is it? I'm asking because i have an RRS grip for my M11(M) and it's much more tight than I’d expected ....ie, I need to push fairly firmly to get the camera to insert down into (and release out of) the bracket given the friction. I've had other RRS brackets for other cameras, and once the bottom screw is released, the bracket will pretty much fall off my itself, but this is certainly not the case with my M11 bracket .....is that normal with the M11 version? Edited April 22 by Jon Warwick Link to post Share on other sites More sharing options...
gbpost Posted April 22 Share #23 Posted April 22 Same here. It is difficult to mount the RRS L-bracket on my M11 with straps attched to the camera because the fitting is very tight. 1 Link to post Share on other sites More sharing options...
lecycliste Posted May 19 Share #24 Posted May 19 (edited) (Duplicate info from earlier post. Couldn’t figure out how to delete it.) Edited May 19 by lecycliste Link to post Share on other sites More sharing options...
