rollsman4 Posted November 5, 2023 Share #1 Posted November 5, 2023 Advertisement (gone after registration) I just purchased this adaptor to use with my 2 Contax 645 lenses on the S007 First Question: When mounting the lens on the adaptor do you first put the adaptor on the body and then attach the lens? OR First put it on the adaptor then attach to the body of the camera Next: Its so tight trying to remove the lens from the adaptor. Is this normal or does it have to get broken in to get where its easy to remove the lens from the adaptor. Thank you 1 Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2023 Posted November 5, 2023 Hi rollsman4, Take a look here Question on Leica S- C Adaptor. I'm sure you'll find what you were looking for!
Guest Posted November 5, 2023 Share #2 Posted November 5, 2023 53 minutes ago, rollsman4 said: I just purchased this adaptor to use with my 2 Contax 645 lenses on the S007 First Question: When mounting the lens on the adaptor do you first put the adaptor on the body and then attach the lens? OR First put it on the adaptor then attach to the body of the camera Next: Its so tight trying to remove the lens from the adaptor. Is this normal or does it have to get broken in to get where its easy to remove the lens from the adaptor. Thank you First question: doesn't matter (in my experience) Second question: Yes, tight is normal. Make sure everything snaps into place. Just out of curiosity: what Contax lenses are you using? Link to post Share on other sites More sharing options...
rollsman4 Posted November 5, 2023 Author Share #3 Posted November 5, 2023 I am using C 645 140 f2.8 and 645 35 f3.5 AF on both Thank you Link to post Share on other sites More sharing options...
Guest Posted November 6, 2023 Share #4 Posted November 6, 2023 3 hours ago, rollsman4 said: I am using C 645 140 f2.8 and 645 35 f3.5 AF on both Thank you Was using the 140 today, it needs a bit of sharpening in post (more than my Leica 120 APO), but otherwise a fine lens, especially for what they go for now. Happy shooting. Link to post Share on other sites More sharing options...
rollsman4 Posted November 6, 2023 Author Share #5 Posted November 6, 2023 Thank you. I appreciate that. Link to post Share on other sites More sharing options...
Einst_Stein Posted November 6, 2023 Share #6 Posted November 6, 2023 (edited) I would minimize the usage of auto focus. I had two bad experiences with other c645 adapters on other cameras. The problem is the power system. C645 (and Contax N) is 6v system ( it would be 4.8v if you use rechargeable battery), while most other cameras are 7.2, 7.4 or higher voltage. The c645 adapters I used try to get fast focus that did not regulate or limit the effective voltage applied to the lens. It ended up over stressed the lens. My first experience is on Sony A7x, it burnt my Contax N lens. Later I heard the adapter power problem has been fixed, and I got a Gfx100s and C645 adapters. In just two days, it burnt a C645 lens. Unfortunately the adapter and the cameras are not from the same company, so it is hard to further pursue the root cause. Friends I know who used S-C combo seem no such problem yet. But I decided to use manual focus mostly. If you find your C-S combo has significant faster AF performance, I would strongly encourage you use manual focus only. Edited November 6, 2023 by Einst_Stein Link to post Share on other sites More sharing options...
ynp Posted November 6, 2023 Share #7 Posted November 6, 2023 Advertisement (gone after registration) 16 hours ago, Einst_Stein said: I would minimize the usage of auto focus. I had two bad experiences with other c645 adapters on other cameras. The problem is the power system. C645 (and Contax N) is 6v system ( it would be 4.8v if you use rechargeable battery), while most other cameras are 7.2, 7.4 or higher voltage. The c645 adapters I used try to get fast focus that did not regulate or limit the effective voltage applied to the lens. It ended up over stressed the lens. My first experience is on Sony A7x, it burnt my Contax N lens. Later I heard the adapter power problem has been fixed, and I got a Gfx100s and C645 adapters. In just two days, it burnt a C645 lens. Unfortunately the adapter and the cameras are not from the same company, so it is hard to further pursue the root cause. Friends I know who used S-C combo seem no such problem yet. But I decided to use manual focus mostly. If you find your C-S combo has significant faster AF performance, I would strongly encourage you use manual focus only. I damaged one of my Contax 140mm on the GFX 50r with the Fringer adapter, maybe it was the voltage problem you mentioned . But I have had zero problems with my Contax lenses on my S2p and S3 and the S-C adapters and I own two of them. And I use my 55mm and 80mm more often than my Leica S lenses. yevgeny Link to post Share on other sites More sharing options...
ynp Posted November 6, 2023 Share #8 Posted November 6, 2023 21 hours ago, rollsman4 said: Its so tight trying to remove the lens from the adaptor. Is this normal or does it have to get broken in to get where its easy to remove the lens from the adaptor. It’s normal. They fit tight and I keep the Contax adapters on my lenses. I have two adapters and both are very tight. Link to post Share on other sites More sharing options...
Einst_Stein Posted November 6, 2023 Share #9 Posted November 6, 2023 2 hours ago, ynp said: I damaged one of my Contax 140mm on the GFX 50r with the Fringer adapter, maybe it was the voltage problem you mentioned . But I have had zero problems with my Contax lenses on my S2p and S3 and the S-C adapters and I own two of them. And I use my 55mm and 80mm more often than my Leica S lenses. yevgeny Good to get one more positive feedback on Leica S-C combo. But I am still not sure if to frequency AF would be OK. I am definitely over cautious. Link to post Share on other sites More sharing options...
Einst_Stein Posted November 6, 2023 Share #10 Posted November 6, 2023 2 hours ago, ynp said: I damaged one of my Contax 140mm on the GFX 50r with the Fringer adapter, maybe it was the voltage problem you mentioned . But I have had zero problems with my Contax lenses on my S2p and S3 and the S-C adapters and I own two of them. And I use my 55mm and 80mm more often than my Leica S lenses. yevgeny The different voltage system does not imply there would be problems.As long as the adapter implemented the voltage regular to match the original voltage, or somehow limit the current, it could be perfect safe. But how would we be sure? I don’t see anyone, including Leica, explicitly mentioned this. The clue Would take is the AF speed, if it is significantly faster than the original Contax 645 AF speed, I would stop using its AF capability. (Fortunately or UNFORTUNATELY, the Leica S-C AF speed is similar to original C645). Link to post Share on other sites More sharing options...
rollsman4 Posted November 6, 2023 Author Share #11 Posted November 6, 2023 I want to thank you all for the valuable info you passed on to me Link to post Share on other sites More sharing options...
John McMaster Posted November 7, 2023 Share #12 Posted November 7, 2023 Why? You are selling it all (again) on getdpi.... john Link to post Share on other sites More sharing options...
