davidhartnyc Posted October 23, 2023 Share #1  Posted October 23, 2023 Advertisement (gone after registration) Hi! Does anyone know anything about the strap lugs on the R system? I have an R7 with a wiggling strap lug. I can't tell if it's getting worse or not and I can't find much information on the topic. Should I have this repaired or is it a normal occurrence? I don't want my camera to fall off and smash on the ground! Thanks for any insight! Link to post Share on other sites More sharing options...
Advertisement Posted October 23, 2023 Posted October 23, 2023 Hi davidhartnyc, Take a look here Leica R7 strap lug wiggles. I'm sure you'll find what you were looking for!
jaapv Posted October 23, 2023 Share #2  Posted October 23, 2023 It is not normal and probably will get worse. The challenge will be finding somebody who will repair it. Link to post Share on other sites More sharing options...
wagner Posted October 23, 2023 Share #3  Posted October 23, 2023 Hi David! Well, had a loose strap lug some years ago on my R4S. Can happen sometimes. There is only one way to sort out that issue: You have to remove the top cover to get access to the screw which holds the lug. Not too difficult. Good luck, Torsten 1 Link to post Share on other sites More sharing options...
davidhartnyc Posted October 23, 2023 Author Share #4  Posted October 23, 2023 Thanks Torsten! Are there any documents or websites that show how to remove the top cover for the R?  I saw a post of yours from 2017 with the R7 top cover removed. Thanks for.your help! Link to post Share on other sites More sharing options...
