MrBan Posted September 12, 2023 Share #1 Posted September 12, 2023 Advertisement (gone after registration) Hi all, My local Leica store doesn't have correction lenses of the required diopter to try. In the meantime I was wondering whether the field of view one can see through the viewfinder, for example the 28mm frame lines, becomes narrower when the correction lens is fitted because the eye is a little further back compared to without the correction lens? I already struggle to see the 28mm frame lines without spectacles, so I am curious whether they will be even harder to see with a correction lens fitted. Thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted September 12, 2023 Posted September 12, 2023 Hi MrBan, Take a look here M10 Correction lens . I'm sure you'll find what you were looking for!
jaapv Posted September 12, 2023 Share #2 Posted September 12, 2023 Please read the forum The best way is to go to your optometrist and use his try-out lenses. The alternative is to use the throw-away spectacles from your local supermarket. The framelines are only minimally affected by a diopter as the eye relief does not change significantly. Link to post Share on other sites More sharing options...
MrBan Posted September 12, 2023 Author Share #3 Posted September 12, 2023 (edited) 10 minutes ago, jaapv said: Please read the forum The best way is to go to your optometrist and use his try-out lenses. The alternative is to use the throw-away spectacles from your local supermarket. Thanks for your response. I do read the forum. Although your reply has nothing at all to do with my actual question, my preferred way to select the correct lens is to try them on the camera. So that is what I will do. Maybe someone else can pipe in with their opinion on the FOV delta with/without the correction lens fitted. Edited September 12, 2023 by MrBan Link to post Share on other sites More sharing options...
jaapv Posted September 12, 2023 Share #4 Posted September 12, 2023 The FOV delta is determined by the eye relief and not specifically by the diopter strength. If you want to try them all you will have to find a compliant dealer who is willing to order them, most have only a few strengths if any at all, or travel to Wetzlar. For us mere mortals the method I described works flawlessly. An alternative is to send your prescription to WalterLeica who will make one for you. Link to post Share on other sites More sharing options...
MrBan Posted September 13, 2023 Author Share #5 Posted September 13, 2023 23 hours ago, jaapv said: The FOV delta is determined by the eye relief and not specifically by the diopter strength. If you want to try them all you will have to find a compliant dealer who is willing to order them, most have only a few strengths if any at all, or travel to Wetzlar. For us mere mortals the method I described works flawlessly. An alternative is to send your prescription to WalterLeica who will make one for you. Thanks. I think I will wait until I can try one. If the FOV difference is no worse than using spectacles, then I will buy one of the correct strength. Link to post Share on other sites More sharing options...
jaapv Posted September 13, 2023 Share #6 Posted September 13, 2023 I can assure you that it is a lot better. Link to post Share on other sites More sharing options...
jaapv Posted September 15, 2023 Share #7 Posted September 15, 2023 Advertisement (gone after registration) Just to show that Leica uses the “hold lens between eye and viewfinder “method: the official diopter choosing tool for dealers. Not in use anymore, sadly. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/381965-m10-correction-lens/?do=findComment&comment=4858302'>More sharing options...
Jeff S Posted September 16, 2023 Share #8 Posted September 16, 2023 We’re all different, including face shape, viewing habits and comfort levels (even for pressing eye against VF), etc. So I agree that the best way to answer these questions is to experiment. I wear glasses (with thin, flexible frames) AND use a +.5 diopter for optimal viewing and focusing. And I have no problem with using my 28 mm lens with the RF. I found what works best for me by visiting my local optician and placing their free trial diopters over the VF, keeping my glasses on (as they correct for distance and astigmatism). All questions answered quickly. Jeff Link to post Share on other sites More sharing options...
Tohna Posted September 16, 2023 Share #9 Posted September 16, 2023 Hi! I tried correction lensed in Prague in Foto-Skoda. Finally I buyed +0.5 correction lens. My hit rate is signifally better now. I wear glasses and I dont see whole frame line when using 28 mm optic. I usually use back screen with 28 mm for focusing and composing Link to post Share on other sites More sharing options...
