Confused. Peak says Micro Clutch strap does not work with Q3, but does with the Q and Q2.  (I version of the strap and not L version) Anybody try it anyway?  I thought Q bodies were essentially the same with exception of battery and SD access.  Is it a case of being unable to access battery and SD when the clutch is on the camera? Is that all?  If it is, I really just use the USB-C port for charging and downloading, so it wouldn't matter.  Anyone try it?
I tried it and returned it. The screw that holds the bottom plate prevents the SD card door from opening. That screw is in the exact same place as the Q2, so I don't know why they say that the Q2 is compatible.
I also found it very uncomfortable; I have large hands, and it forces your hand in a position that, for me, was not bearable for long. It made it very difficult to get my index finder on the shutter.
14 hours ago, SAH said:
Ah- that might make sense - they may not have had a Q3 to work with when the design/production happened?
Doesn't matter. I compared my Q2M to the Q3, and the bottom is exactly the same. Could the Q2 be different than the Q2M
Where is the problem with the Micro Clutch?
