Shane Oneill Posted July 29, 2023 Share #1 Posted July 29, 2023 Advertisement (gone after registration) i had set my photo file format to shoot DNG and thumbwheel button to perspective contriol but without me changing anything the file format went to dng & jpeg and the thumbwheel button to iso. this has happened before with other FN buttons and settings and is very frustrating. has anyone else experienced this and know what the cause may be ? thnaks Link to post Share on other sites More sharing options...
Advertisement Posted July 29, 2023 Posted July 29, 2023 Hi Shane Oneill, Take a look here SETTINGS & FUNCTION BUTTONS KEEP CHANGING . I'm sure you'll find what you were looking for!
Le Chef Posted July 29, 2023 Share #2 Posted July 29, 2023 The camera keeps returnIng to default settings when you switch off and then switch on. You need to save your preferences by creating a profile. There’s a section in the instruction manual that explains how to do this. 1 Link to post Share on other sites More sharing options...
Shane Oneill Posted July 30, 2023 Author Share #3 Posted July 30, 2023 thanks, it's a bit finnicky but sorted now shane Link to post Share on other sites More sharing options...
Shane Oneill Posted July 30, 2023 Author Share #4 Posted July 30, 2023 i thought i had it but just switched off and back on again and the same thing has happened. is there a thing you need to do to save it when you have put all your settings in? thanks Link to post Share on other sites More sharing options...
Shane Oneill Posted July 30, 2023 Author Share #5 Posted July 30, 2023 can you delete the default setting? Link to post Share on other sites More sharing options...
Stephen_C Posted July 30, 2023 Share #6 Posted July 30, 2023 2 hours ago, Shane Oneill said: can you delete the default setting? No. Just create all the settings you need and then save them to one of the other profiles. (You can rename the profile if you wish: see the downloadable user manual.) Stephen Link to post Share on other sites More sharing options...
Shane Oneill Posted July 30, 2023 Author Share #7 Posted July 30, 2023 Advertisement (gone after registration) Than ks stephen can you make your created profile the default one ? Link to post Share on other sites More sharing options...
Le Chef Posted July 30, 2023 Share #8 Posted July 30, 2023 It’s easier to get the favorite settings in order.then go to the menu that says “User Profile”. Then “Manage Profiles then “Save as” and pick the first empty profile. You can “Rename profile” so it’s called something useful/memorable. Then to be sure select “Save as” again and pick the name of the profile you created. It’s a bit fussy, but once you’ve done it, that’s it, Link to post Share on other sites More sharing options...
M11 for me Posted July 30, 2023 Share #9 Posted July 30, 2023 vor einer Stunde schrieb Shane Oneill: Than ks stephen can you make your created profile the default one ? Yes and no. Whenever you have choosen a profile that profile will remain active. Even when switching your camera off and on again your previous profile is still active. But note that whenever you change some setting then the choosen profile is not unchanged anymore. You made a change. When switching your camera off and on again you do NOT have the original profile active anymore. In that case go into your overview menu (the one with the icons) and select your profile. This action will reset the profile you originally set. Link to post Share on other sites More sharing options...
Shane Oneill Posted July 30, 2023 Author Share #10 Posted July 30, 2023 thanks everyone Link to post Share on other sites More sharing options...
