Hi Shane Oneill,
Check out this option for your Leica Q3 here. It could be just what you need for fill-in.
I have the Leica SF40, which is an over-kill as a fill flash even though it's pretty small and not that powerful.  For fill, you can probably use a number of third-party manual flashes without having shell out big bucks for Leica flashes (which are made by other manufacturers by the way).  All the Leica flashes are made by third-party manufacturers - SF 28 and SF-58 are made by Metz and the SF-40 is made by Nissin.
I've recently bought the FLASH Q Q20. It's a great flash, it has a remote trigger included in the flash, so you can detach it and use it as external flash for filling.
https://erickoke.wordpress.com/2020/11/19/flash-q20-review/
I'ts very small and has many features, even a modeling led light.
Edited by StefanoGili
if the godox is compatible with the Q3 and is also compatible with fuji x100 series and olympus pen series does that mean my small flashes for the fuji and olympus will be compatible with the leica Q3?
sorry i dont know much about flashes or how they work. i just want a very small, compatible flash i can carry around should the need arise
thanks
It depends what you mean by compatible. As far as I am aware no non-Leica flash can communicate with a Leica body for TTL automatic flash control. However most third party flashes can be triggered from a Leica body from a centre pin, so can be used in manual or 'Auto' mode (i.e. when the flash has its own light sensor and chooses its power setting after you have told it the aperture and ISO).
On 7/17/2023 at 4:12 PM, LocalHero1953 said:
Leica SF 24D
That would be the official recommendation. I don't have it, but I am sure it would do the job - at a price.
Just purchased the SF 24D used to use with the Q3 - based on lots of positive reviews and it's small size, however it does not seem to support TTL mode on the Q3 - not sure if mine is defective or that's just how the Q3 works.
I like the Fujifilm flash, I think it’s the EF-X20. Setting the flash manually doesn’t bother me. Love the small size and works very reliably for me when needed. I also use a Nikon flash cable for when I want to move location of flash off top of camera. I think it’s the SC-17 TTL cable.
Same experience as Simone_DF here.  I use a mix of Godox V860IIN, V350N, and some others I can’t remember but they all work without issue on my Ms, Qs, and SL2.  I even have the round head Godox in Canon pinout and it works just fine.  Also use AD200 portable strobes and the X-Pro N and X-Pro F triggers without fault.
On 7/18/2023 at 5:36 AM, Shane Oneill said:
Can anyone recommend a compatible small flash for the Q3
only to be used for fill in
Hello Shane,
I managed to acquire the Leica SF26 - second hand but in very good condition. Like all Leica badged accessories, it was probably over-priced, but the form factor - it can be folded down on camera - and has multiple angles for fill, bounce etc matches well with the Q3. It works with the Q3 - TTL with variables such as shutter speed and f stop etc all giving accurate results, plus it can be used as a slave and has a small "video light".  Like some other "earlier" models, it is quite a tight fit mounting it into the Q3 shoe. There is a release button that needs to be pressed to aid in mounting the SF26 on the Q3 shoe. I did try using a dremel to (carefully) file away some of the SF26's metal mounting foot, but I'm not sure this made much of a difference - possibly a little.
But the SF 26 works, has a small form factor that you wanted, and has the added bonus of TTL with the Q3.  You can reduce the power output directly from the Q3 menu for fill flash or other effects.  I had to hunt around for a while before finding one from a Japanese Leica camera store - so extra postage to Australia.
Paul
Am 23.7.2023 um 14:37 schrieb Anakronox:
But you can get the X-Pro Trigger for Leica, then TTL should work
I know, but that doesn’t help if I need to use the flash on-camera, which I do sometimes.  Still never use TTL, even with the SF-60 but I know what you mean.
