Scanner Advice
Ronazle
Hello all. I just sent a check for a Nikon 8000 to begin scanning my many Leica and medium format negatives & positives (I think I've been corrupted by my reasonably well working M8). Given the fact that the scanner choice has been made, what actions particular to a Nikon 8000 should be undertaken or avoided? I would really like to profit from other's mistakes rather than make my own. Also, should I go with early software or update the software? Why? In advance, thank you so much. Ron
Ron,
NikonScan is ok. I did benefit a lot from both VueScan and SilverFast, mainly because of it's it8 calibration. However, with more scanning experience the need for it8 calibration is deminishing. I prefer SiverFast and probably a lot of german forum mebers do as well. VueScan does have certain advantages and is a lot cheaper. If you realy want the utmost quality try to learn both...which of course is the hard way.
Harald
Thanks for the advice. I'll probably try Vuescan due to its bargain price and lack of obnoxious usage restraints.It was somewhat shocking to see Silverfast being priced about the same as a vintage Summicron, regards, rt
I'm batsh-scanning my dia pictures during the diafeeder, it works quite well.
I have turned off all funktions in The Nikon 5000 scanner. The pictures comes out exactly the way they are exposed. If the picture is perfect, the scanning is also perfect. the result is great.
The scanner is not stopping overheated after about 50 pictures anymore.
If needed I do the correctingwork in Ph.
The workflow is about the same as to use M8 ,RAW and have it all in copies (ex.Jpg) to daily use.
I save time here it's not realistic to go any other way if is is many pictures to have done .
During 30 years photographing 36 pictures every month, it will sum up to 12960 pictures.
After a few days with this work I have started to use the M6 again.
/Ted
  • 3 weeks later...
Ron,
Harald
Harald, Scanner came and is working well. The rollfilm carrier was broken, but the broker (not the owner) made it good. I have tried both Nikon Scan and Vuescan and found the Vuescan to be quite superior. Also, Vuescan has breathed new life into my Canon 9900F. Thanks again for the advice, perhaps SilverFast is in my future. Regards, Ron
I haven't found VueScan to be particularly noisy. It allows for various levels of noise reduction as necessary. It's so reasonably priced and efficient that there's no reason not to own it. As I recall it allows for lifetime updates.
The Nikon 8000 doesn't have the digital ICE feature that so many other Nikon film scanners have. That means you'll find yourself having to retouch dust spots, scratches, etc.
VueScan is way easier and more convenient than the bloatware that ships with Nikon.
I suspect I'll be using Vuescan for some time. Yes, it does allow for lifetime updates, which is a rather attractive feature. I've heard others say that 8000 doesn't have digital ice which leads me to believe some (early ones?) may not have had it; however, this one does and it so states on the front panel.regards, ron
