Hello,
I’ve recently purchased a Q2 and have been setting it up.  I’m curious what setting you’re all using for the EVF frame rate?
Looking online, it seems that this setting was described as follows: “A Variable EVF frame rate menu was added, enabling users to choose between 60fps or 120 fps. For fast moving subjects set 120 fps for a more fluid display of movement (with lower resolution) or choose 60 fps for full resolution.”  Does using 120 fps significantly lower the resolution?
Thanks,
Tom
x
  • 1 year later...
On 6/22/2023 at 6:07 PM, nicci78 said:
Just choose 120 fps no real downside
Unfortunately, this is not the case. When you select 120, the screen resolution drops noticeably. To see this, try opening the aperture and focusing on jeans or some other fine-meshed surface. You will also get moire if set to 120. That's why I usually use 60.
At least on Q3 43 the difference is very noticeable
Edited by Smogg
