kirkmc Posted June 22, 2023 Share #1 Posted June 22, 2023 Advertisement (gone after registration) On the Q2, you can put the Leica supplied lens cap on top of the lens hood. Presumably, since the Q3 comes with the rectangular lens hood, it has the same lens cap. But if you buy the accessory lens hood, then you will no longer be able to fit the lens cap on top of it, right? From the photos I’ve seen, the lens hood diameter looks larger than that of the lens cap. Link to post Share on other sites More sharing options...
Advertisement Posted June 22, 2023 Posted June 22, 2023 Hi kirkmc, Take a look here Q3 Lens hood and lens cap. I'm sure you'll find what you were looking for!
kirkmc Posted June 23, 2023 Author Share #2 Posted June 23, 2023 No replies to the above, but I have another question. It looks like the new aftermarket lens hood screws onto the 49mm lens or filter thread, not the outer thread that the rectangular lens hood screws on, is that correct? It seems that the outer thread is 60mm, and there don't seem to be many lens hoods available that size. Link to post Share on other sites More sharing options...
beewee Posted June 23, 2023 Share #3 Posted June 23, 2023 I thought it was pretty obvious that the lens cap that ships for the rectangular hood will not fit over the top of the much bigger optional vented round hood. Regarding screw on Leica hood vs third-party, the Leica hood has a patented design that ensures the hood always stops in the same position when you thread it on. There’s a notch to stop the hood from turning once it is properly aligned. As it is a patented design, you won’t find any non-Leica hood with the same feature. 1 1 Link to post Share on other sites More sharing options...
JoeInCT Posted May 26 Share #4 Posted May 26 (edited) You are correct.the lens cap that ships with the camera is too small to fit on the accessory round ventilated hood that Leica makes. I am trying to find a solution for this because I still want a cover for the lens hood to protect the opening when it is in my camera bag. There are neoprene lens covers that stretch over the lens and could cover the round accessory hood but I’m not sure what size to buy. Edited May 26 by JoeInCT Link to post Share on other sites More sharing options...
JohnW. Posted May 27 Share #5 Posted May 27 This is the Haoge round lens hood and cap fitted to my Q. The cap clips inside the hood which has threads (49mm) for filters. The hood screws onto the outside of the lens, the same as original lens hood. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/378636-q3-lens-hood-and-lens-cap/?do=findComment&comment=5807915'>More sharing options...
