2mme Posted June 17, 2023 Share #1  Posted June 17, 2023 Advertisement (gone after registration) Hello everyone, Do you know if an IR filter with e44 thread has ever been produced? Or by the 6 series (to be used with adapter ring)? I have an old Summicron-R 1:2/50 (cod.11228) with this diameter and I can't find anything compatible (not even, alternatively, a normal red filter)... 😞 Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2023 Posted June 17, 2023 Hi 2mme, Take a look here Is there an IR (or red) E44 filter?. I'm sure you'll find what you were looking for!
frame-it Posted June 17, 2023 Share #2 Â Posted June 17, 2023 use step rings? then check Kolari or Baader https://www.robertallenkautzphoto.com/leica-filter-size-chart-1 1 Link to post Share on other sites More sharing options...
dpitt Posted June 17, 2023 Share #3 Â Posted June 17, 2023 2 hours ago, frame-it said: use step rings? then check Kolari or Baader https://www.robertallenkautzphoto.com/leica-filter-size-chart-1 I see 2 ways to use a filter: 1. Use these cine mod adapters to convert from the S6 series thread to E80 mm. Be careful S6 uses a different pitch than E44 so finding a E44 filter would not completely solve the issue. https://www.precisious.fr/fr/bagues-d-objectif-frontales-lens-mod/20-612-ring-cine-77mm-80mm-od-adaptateur-lens-mod.html#/151-diametre-s6 2. Find a S6 holding ring and use an appropriate size of E-filter to hold it (without screwing it in) Leica filters will work best because their rim is thinner. Also, using the E filter upside down will be necessary. Link to post Share on other sites More sharing options...
frame-it Posted June 17, 2023 Share #4 Â Posted June 17, 2023 27 minutes ago, dpitt said: I see 2 ways to use a filter: 1. Use these cine mod adapters to convert from the S6 series thread to E80 mm. Be careful S6 uses a different pitch than E44 so finding a E44 filter would not completely solve the issue. https://www.precisious.fr/fr/bagues-d-objectif-frontales-lens-mod/20-612-ring-cine-77mm-80mm-od-adaptateur-lens-mod.html#/151-diametre-s6 2. Find a S6 holding ring and use an appropriate size of E-filter to hold it (without screwing it in) Leica filters will work best because their rim is thinner. Also, using the E filter upside down will be necessary. perhaps you should reply to the OP? Link to post Share on other sites More sharing options...
Pyrogallol Posted June 17, 2023 Share #5  Posted June 17, 2023 6 hours ago, 2mme said: Hello everyone, Do you know if an IR filter with e44 thread has ever been produced? Or by the 6 series (to be used with adapter ring)? I have an old Summicron-R 1:2/50 (cod.11228) with this diameter and I can't find anything compatible (not even, alternatively, a normal red filter)... 😞 If this is the same lens you have, an E39 filter, put in backwards, will fit in with a series VI retaining ring. It will rattle a bit but should not fall out. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/378404-is-there-an-ir-or-red-e44-filter/?do=findComment&comment=4795745'>More sharing options...
2mme Posted June 18, 2023 Author Share #6 Â Posted June 18, 2023 WOW, it's very tricky, but YES it's the same lens, so i trust it'll work!! Thank you all so much for the contributions Link to post Share on other sites More sharing options...
