Hi
I noticed that my SL2 sometimes loses the settings.
For example:
a) Recording only enabled as RAW, sometimes JPG and RAW are recorded
b) Autofocus activated with sound, sometimes there is no acoustic signal.
So far I haven't found a cause
Has anyone already observed lost settings?
Jochen
On 6/2/2023 at 1:16 PM, spassig123 said:
Hi
For example:
Jochen
Never experienced with any of the three versions of the SL-body that I have used (currently SL2-S). Can't recall that I have read about it either...
You are likely on the latest firmware. If not, upgrade. And have your user settings stored on the memory card (and that the card is working fine).
If too brothersome, I fear that the body needs a check at Wetzlar. But other users may chime in with their experience and recommendations.
See also
Edited by helged
On 6/2/2023 at 2:16 PM, spassig123 said:
Hi
For example:
Jochen
Have you saved these settings as a User Profile? It could be caused by selecting (or the camera defaulting to) a User Profile that has different settings for these parameters.
