Richard Alton Posted May 7, 2023 Share #1  Posted May 7, 2023 Advertisement (gone after registration) Wanting to chimp and get a closer view of a picture I had taken, I recently tried to turn the command dial on my M8 and found it stuck. The arrow functions work, so it's not a tragedy if the dial remains stuck. Is this a common problem on the M8? And can it be fixed at a reasonable cost? Any advice is appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted May 7, 2023 Posted May 7, 2023 Hi Richard Alton, Take a look here Command dial on my M8 won't turn. I'm sure you'll find what you were looking for!
jaapv Posted May 7, 2023 Share #2 Â Posted May 7, 2023 Never heard of this; somebody else might. The repair will not be cheap, if at all possible. Link to post Share on other sites More sharing options...
david strachan Posted May 8, 2023 Share #3  Posted May 8, 2023 Try squirting a bit of electronic cleaner into the command dial. ..and gently work back and forth until free. I once had trouble with one of my M8's command dial...it would jump in its magnifications. I think dander accumulated and needing cleaning. This worked well..."CO Contact Cleaner" made by CRC in a spray can. Says'...Precision electronic cleaning solvent...leaves no residue...low in toxicity..." I've used it on other electronica too...now wouldn't be without it. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/376516-command-dial-on-my-m8-wont-turn/?do=findComment&comment=4766811'>More sharing options...
Graham (G4FUJ) Posted May 8, 2023 Share #4 Â Posted May 8, 2023 The important bit with contact cleaner is the "no residue" statement 1 Link to post Share on other sites More sharing options...
