[Comparison] Leica M11 vs Sony A7RIII (with Summilux 50mm f/1.4 ASPH)
Just got the M11 and was curious to see the differences sensor-wise. Sharing in case someone else finds it useful.
  • The Summilux 50mm f/1.4 ASPH was used on both cameras (with the Voigtlander VM-E adapter on the Sony)
  • Cameras were mounted on a tripod and focus acquired via live view.
[Left] A7RIII (42.4 MP) - f/1.4 | 1/160s | ISO 100
[Right] M11 (60 MP) - f/1.4 | 1/250s | ISO 160
Raw | No sharpening | 100% zoom
Raw | Sony - default Lightroom sharpening (40), Leica - sharpened to match the Sony (70) | 100% zoom
JPG without any tweaks | 100% zoom
Edited by neonvoid
Full size | WB/Exposure/Contrast adjusted slightly on the Leica to match Sony | 2000 pixels on the long edge | Sharpened for screen
Leica M11
Sony A7RIII
Edited by neonvoid
Why did you use lower exposure with M11?
34 minutes ago, neonvoid said:
Wasn’t intentional, that’s the aperture priority mode and auto ISO doing its thing.
OK. When comparing two cameras, you should strive to have the same exposure.
12 minutes ago, Photoworks said:
What is the point of this test?
The Leica DNGs seemed a bit soft so I needed to confirm that I'm not imagining it.
They are softer compared to Sony RAW files, not sure why. It has little effect on the end result though, after a bit of sharpening the files are almost identical.
As always, AWB is far more noticeable than anything else.
Regardless, you need to equalize the file sizes to make a fair comparison. After that, I'd suggest you place the target in one of the extreme corners. There's not a lot of bend with the 50mm 'lux***, but likely enough to see some effects of thicker cover glass vs. thinner + microlensing.  Center frame, no refraction effects will be evident, but the corners are another matter. Try a 28mm and you'll see an obvious difference.
*** [edit] especially at close focus distances where the lens is further from the sensor.
Edited by Tailwagger
