Mucleica Posted April 11, 2023 Share #1 Posted April 11, 2023 (edited) Advertisement (gone after registration) By accident I exposed the HP5 at 125 instead of 400. I have HC110 or Rodinal available. Any good experience here, how to develop it decently? thank you in advance. It’s a medium format film. Edited April 11, 2023 by Mucleica Additional info Link to post Share on other sites More sharing options...
Advertisement Posted April 11, 2023 Posted April 11, 2023 Hi Mucleica, Take a look here Ilford HP5+ @ ISO 125. how to dev? . I'm sure you'll find what you were looking for!
andybarton Posted April 11, 2023 Share #2 Posted April 11, 2023 Try this https://www.digitaltruth.com/devchart.php?Film=Ilford+HP5%&Developer=HC-110%&mdc=Search&TempUnits=C&TimeUnits=D and read this You have to start somewhere and with a single film exposed like that you can't experiment easily. B&W film has a wide latitude, so I'm sure that you will get useable results. 1 Link to post Share on other sites More sharing options...
Fotoklaus Posted April 11, 2023 Share #3 Posted April 11, 2023 With HC110 the developing time might be too short (5Min. for Dilution B and ISO 400) so I would try Rodinal 1:50 at about 5-6 Minutes. Link to post Share on other sites More sharing options...
Pintpot Posted April 11, 2023 Share #4 Posted April 11, 2023 Overexposure & underdevelopment should give you a somewhat 'flat' negative, this will be easily corrected in printing or scanned & corrected in post process. What it also should do is give more detail in the shadow areas. As Andy says B/W film has a wide latitude, good luck & do post some results. Link to post Share on other sites More sharing options...
andybarton Posted April 11, 2023 Share #5 Posted April 11, 2023 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/375375-ilford-hp5-iso-125-how-to-dev/?do=findComment&comment=4747696'>More sharing options...
BernardC Posted April 11, 2023 Share #6 Posted April 11, 2023 8 hours ago, Mucleica said: By accident I exposed the HP5 at 125 instead of 400. I have HC110 or Rodinal available. Any good experience here, how to develop it decently? You aren't that far from a normal exposure. You need to give it a little less development so the highlights don't block. I would try either diluting the developer more (less developer, more water to make-up the required volume), or a slightly shorter development time. For instance, if your normal dev time is "8 minutes in Rodinal at 1:50", I would either try 7 minutes, or a 1:60 dilution. You don't need to make a big change, because that will give you low-contrast negatives. You'll still get dense negatives, but that can be compensated by longer printing times, or more exposure in your scanner. Link to post Share on other sites More sharing options...
BernardC Posted April 11, 2023 Share #7 Posted April 11, 2023 Advertisement (gone after registration) I should mention that you can run a test if these are very important negatives. Expose another roll at ISO 125 and develop it as per my instructions. Link to post Share on other sites More sharing options...
Mucleica Posted April 11, 2023 Author Share #8 Posted April 11, 2023 Thank you all. Once done I will post thE results Link to post Share on other sites More sharing options...
Mucleica Posted April 15, 2023 Author Share #9 Posted April 15, 2023 So, I did a 1:41 instead of the B 1:31 dilution of Kodak HC-110. And then my usual 6 minutes at 20 C with 1st minute constant, and then 10 sek per minute agitation. The negatives look quite good, not to dense. I expect good results later in Lightroom. I will post once they are dry and 'scaned' with my Nikon D850. Link to post Share on other sites More sharing options...
Mucleica Posted April 15, 2023 Author Share #10 Posted April 15, 2023 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/375375-ilford-hp5-iso-125-how-to-dev/?do=findComment&comment=4751170'>More sharing options...
Mucleica Posted April 15, 2023 Author Share #11 Posted April 15, 2023 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/375375-ilford-hp5-iso-125-how-to-dev/?do=findComment&comment=4751175'>More sharing options...
Aryel Posted April 21, 2023 Share #12 Posted April 21, 2023 (edited) Looks like they came out very nicely without blown highlights 👍🏻 I’d tend to photoshop out the scratch on the dog photo as I find it distracting. It is a nice photo! Edited April 21, 2023 by Aryel 1 Link to post Share on other sites More sharing options...
