Rant on Firmware Updates
barjohn
  • Replies 130
  • Created
  • Last Reply
Guest tummydoc
Can't say more but i asked if they can put a description of what is in the update , so there is no guessing
Unless their Babelfished description is as vague and confusing as it typically is :confused:
http://www.l-camera-forum.com/leica-forum/forum-zur-leica-m8/37929-firmwareupdate-1-110-a.html
Haven't read much of the thread, but this was posted in german forums.
Rough translation:
- 6bit codes for Summarit 35, 50, 75, 90 added
- time frame between pre-flash and main-flash shortened in M-TTL mode with SF 24D and SCA compatible flashs
- function of the menu wheel improved (skipping of menu should be gone)
- battery life display accuracy improved
- text in french version changed
That's it, should be available today.
Dirk
Rough translation:
Dirk
hmm, according to my german, it doesn't actually say 'skipping should be gone', it says 'running through menus now prevented' whatever that means...
surprise, surprise some of the rest of the thread is about 8 bit vs 14bit! you have to laugh
Guy,
that is correct - but tbh, I don't know what they mean by "running through the menus", so I took they meant the skipping thing. :D
90% of understanding their publications is done by interpretation - something, that would be prevented by clearly acknowledging problems and actually naming them.
Guest guy_mancuso
Just in case you forgot how to do this
Instructions for updating the LEICA M8 Firmware
1. Format a memory card in your LEICA M8.
2. Turn off the camera and insert the card into an SD card reader – either integrated or connected to
your computer. (A reader is required for Firmware updates).
3. Download the Firmware file from the Leica M8 site using the “UPDATES” link and unzip the file.
4. Save the unzipped file m8-1_xx.upd at the top level of the card’s folder structure. xx stands for
the version.
Top level of card’s folder structure
5. Remove the card properly from your card reader, insert the card into the camera and close the
bottom cover.
6. Turn on the camera using the main switch and wait for at least 3 seconds before continuing
with step 7.
7. Confirm the prompt that appears in the monitor as to whether you want to update the Firmware
on the camera to version 1.xx.
The update process takes around 180s. You will then be prompted to restart the camera using the
main switch.
8. Turn the camera off and back on again.
Note:
If the battery does not have sufficient charge, you will see a corresponding warning message.
Firmware version 1.110 - The update adds these improvements to your camera:
6 Bit lens codes for Summarit-M lenses 35, 50, 75 and 90 mm
Time shortened between pre-flash and main flash in M-TTL mode with flashes LEICA SF24
D and SCA compatible flashguns
function of the central setting wheel on the camera back improved (unintentional scrolling
of the menu now prevented)
battery capacity display improved
Change in the French menu: «Marche +UV/IR» instead «Marche avec»
I think they are referring to venetion blind effect and also fast scrolling on it' own
