Have you seen the informative “youtube by F/Stops” that explains how 1/64 and 1/32 strengths can be flexibly changed on the fly whilst utilizing ISO1600 and f4 with the EF-X20 on  a Leica Digital M.
It was titled :
This is some serious “on-camera” flash! What a gem!
I personally find the Leica SF26 to be outstanding, and the TTL pre-flash is almost invisible to the subjects
Edited by dugby
The flash in nice and small is night situations.
It was underpowered in outdoor sunny situation, and the batteries are small.
The one i was using on the Q2 was a little snuggle fit, it was pushing down on the top plate.
At the end i found TTL more useful in fluid situation going in and out , indoor and outdoor like an event.
It was titled :
Now checking 🙏🏻👍
  • 2 years later...
So the TTL worked flawless on the m11? Was thinking about the sf40 but that one is just so much bigger in size
2 hours ago, dav3 said:
i know the leica ones do but how about the Fuji EF-X20
no other flash does TTL on the M11 on the hotshoe. the only other TTl option is Profoto L-trigger and latest profoto lights
I have this combination. The Fuji X-20 flash is a nice compact unit but can only be used in manual mode on the Leica.
I don't think it is made anymore.
Regards,
Bud James
In that case there is the SF 26
  • 4 weeks later...
Posted (edited)
I tried the im30.  it was a bit uncomfortable as the hotshoe is at the rear of the m11 and the flash doesn't taper forwards, so as a left eye user it kind of was always pressing my forehead/eyebrow.  its a decent flash for the money though, manual mode is fine.  it really benefits from some serious diffusion as its pretty harsh even on lower power - some trace taped over worked well.
my m11 went weird after using it each time though. wouldn't turn on properly.  finally it would come to life after 5 mins or so.  I put it down to another Leica weirdness, #962 .... but maybe it was just my body.
incidentally, after using the flash the first time, the hotshoe cover was lose and barley stayed in.  Leica weirdness #963
Edited by Velo-city
