Hi there. I have two Leica mp units. 2003 and 2022 manufacture year. This winter I find some problems with light meter in old 2003 camera. After some minutes 5-10, outside, light meter stop working, but there is a small minus degrees on street -1/-5c. My new unit working fine after -5 and -10. No problems. I try to replace battery but it doesn’t help. What should I do? How to fix problem and where is it ? Thanks you
P.s- no official service in Ukraine, where I am
is it due to the cold weather? if u have replaced the battery with new ones and don't help, may be there's a different temperature drop resistance to the newer MP? but it didn't mean it's a problem, may be just an old thing that needs to be improved or upgraded upon
it still works normally under room temperature yes?
  • 2 weeks later...
1 hour ago, monark33 said:
yes inside all fine. outside no (
       ...try giving all battery contacts on MP X a good, robust clean to eliminate that factor, before exchanging the existing battery with a demonstrably functional battery from MP Y. Good luck.
