ellisson Posted February 15, 2023 Share #1 Posted February 15, 2023 Advertisement (gone after registration) This may have been discussed previously, but I am looking for help in opening the SL2-S firmware version 4.0 (and likely other firmware updates from Leica) on my MacAir computer. The file extensions are .lfu, which my computer is not "accepting", asking for an app to do this. I am unable to locate an app that will work with this file extension. Suggestions on how to open the firmware so that I can move it to an SD card are most welcome! In the meanwhile, I'm using firmware version 1.0 for the SL2-S. Not optimal. Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 15, 2023 Posted February 15, 2023 Hi ellisson, Take a look here How to open download of SL2-S firmware. I'm sure you'll find what you were looking for!
frame-it Posted February 15, 2023 Share #2 Posted February 15, 2023 (edited) 12 minutes ago, ellisson said: Suggestions on how to open the firmware so that I can move it to an SD card why would you want to "open" the file? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 15, 2023 by frame-it Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/366845-how-to-open-download-of-sl2-s-firmware/?do=findComment&comment=4687331'>More sharing options...
ellisson Posted February 15, 2023 Author Share #3 Posted February 15, 2023 I can get the file into the download section, and I moved it to the SD card as per the instructions. But it does not register in the camera information/firmware section. The message “no firmware file” comes up. Quote Link to post Share on other sites More sharing options...
frame-it Posted February 15, 2023 Share #4 Posted February 15, 2023 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! >>>>>>>> Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! >>>>>>>> ' data-webShareUrl='https://www.l-camera-forum.com/topic/366845-how-to-open-download-of-sl2-s-firmware/?do=findComment&comment=4687422'>More sharing options...
SrMi Posted February 16, 2023 Share #5 Posted February 16, 2023 (edited) 43 minutes ago, ellisson said: I can get the file into the download section, and I moved it to the SD card as per the instructions. But it does not register in the camera information/firmware section. The message “no firmware file” comes up. You downloaded the wrong firmware. 4.0 is for the SL2. SL2-S firmware is 3.0. Edited February 16, 2023 by SrMi Quote Link to post Share on other sites More sharing options...
frame-it Posted February 16, 2023 Share #6 Posted February 16, 2023 6 minutes ago, SrMi said: You downloaded the wrong firmware. 4.0 is for the SL2. SL2-S firmware is 3.0. 4.0 is for the SL2s, 5.0 is for the SL2 Quote Link to post Share on other sites More sharing options...
ellisson Posted February 16, 2023 Author Share #7 Posted February 16, 2023 Advertisement (gone after registration) I downloaded version 4.0 for the SL2-s. I copied it onto a re-formatted fast, 128gb SD card. Into the camera SD 1 slot, nothing in the SD 2 slot. Then turned camera on and went to firmware area of the menu to update. Then got message “no firmware found on SD card. Quote Link to post Share on other sites More sharing options...
frame-it Posted February 16, 2023 Share #8 Posted February 16, 2023 check the name of the file Quote Link to post Share on other sites More sharing options...
SrMi Posted February 16, 2023 Share #9 Posted February 16, 2023 (edited) 22 minutes ago, ellisson said: I downloaded version 4.0 for the SL2-s. I copied it onto a re-formatted fast, 128gb SD card. Into the camera SD 1 slot, nothing in the SD 2 slot. Then turned camera on and went to firmware area of the menu to update. Then got message “no firmware found on SD card. If you downloaded the file multiple times, its name gets mangled with a number so the previous download does not get overwritten. Can you share the exact name of the firmware file? Edited February 16, 2023 by SrMi 1 Quote Link to post Share on other sites More sharing options...
ellisson Posted February 16, 2023 Author Share #10 Posted February 16, 2023 (edited) SL2-S40_ (1).lfu. That's the file. Tim Ketzer from Leica Customer Service sent me a link after I mentioned my problem. But the same "no firmware found" message persists. I downloaded the 4.0 file before his link, and that file is SL2_S40.lfu. File sizes are identical (116.5 mb) Edited February 16, 2023 by ellisson typo Quote Link to post Share on other sites More sharing options...
SrMi Posted February 16, 2023 Share #11 Posted February 16, 2023 (edited) 23 minutes ago, ellisson said: SL2-S40_ (1).lfu. That's the file. Tim Ketzer from Leica Customer Service sent me a link after I mentioned my problem. But the same "no firmware found" message persists. I downloaded the 4.0 file before his link, and that file is SL2_S40.lfu. File sizes are identical (116.5 mb) The name is the problem. The firmware file on the SD card has to have the name SL2_S40_.lfu. Any other name will not work. Edited February 16, 2023 by SrMi Quote Link to post Share on other sites More sharing options...
frame-it Posted February 16, 2023 Share #12 Posted February 16, 2023 2 hours ago, ellisson said: SL2-S40_ (1).lfu. That's the file. Change the name to SL2-S40_.lfu Quote Link to post Share on other sites More sharing options...
ellisson Posted February 16, 2023 Author Share #13 Posted February 16, 2023 (edited) Still getting same message after deleting the first file, re-formatting the SD card, then adding the SL2-S40_.lfu file. The camera does not read a firmware file on the card. Strange. Edited February 16, 2023 by ellisson Quote Link to post Share on other sites More sharing options...
Virob Posted February 16, 2023 Share #14 Posted February 16, 2023 20 minutes ago, ellisson said: Still getting same message after deleting the first file, re-formatting the SD card, then adding the SL2-S40_.lfu file. The camera does not read a firmware file on the card. Strange. Perplexing. That is strange. Sounds like you are doing it right. Just to be sure, the SD card was formatted in the camera, yes? The only other thing I can think of is that you are trying to go from version 1.0 to 4.0. Maybe that is too big a jump. You could try updating to version 2 and see if that works. Quote Link to post Share on other sites More sharing options...
ellisson Posted February 16, 2023 Author Share #15 Posted February 16, 2023 Thanks Virob. I will try upgrading to 2.0, and if that works, continue in sequence. Quote Link to post Share on other sites More sharing options...
LeicaR10 Posted February 16, 2023 Share #16 Posted February 16, 2023 Ellisson, I just sent you an PM to help you through the process. If you need more help, drop me a PM back. r/ Mark Quote Link to post Share on other sites More sharing options...
ellisson Posted February 16, 2023 Author Share #17 Posted February 16, 2023 The problem was my carelessness in adding the firmware update file to the SD card. As noted in the "Preparation" column of the Notes file that describes the detailed procedure (posted by frame-it, above), the file should just be added to the card, not to a subdirectory such as DCIM or Private. That was my error. Simple carelessness. All is good. Quote Link to post Share on other sites More sharing options...
