moky99 Posted January 21, 2023 Share #1 Posted January 21, 2023 (edited) Advertisement (gone after registration) Hello I plan to buy a Voigtlander Skopar 21 f/3.5 and Voigtlander 75 1.5 Nokton for my M10 monochrom... How do you manage to get a frame in the viewfinder similar to the 21 or 75 mm ? Do you choose a setting in the M10 and select a 21 or 75 Leica lens ? Or do you trust M10 LCD panel for framing ? Thanks a lot Edited January 21, 2023 by moky99 Link to post Share on other sites More sharing options...
Advertisement Posted January 21, 2023 Posted January 21, 2023 Hi moky99, Take a look here Voigtlanders and Leica M10M viewfinder . I'm sure you'll find what you were looking for!
Stef63 Posted January 21, 2023 Share #2 Posted January 21, 2023 (edited) Visoflex is the logical answer. Either the 020 version or the Visoflex 2. The latter is also compatible with the M11. … or if you want to go vintage (not necessarily cheaper) https://store.leica-camera.com/at/en/leica-brightline-viewfinder-m-21-mm-black-lacquered for the 21 mm Edited January 21, 2023 by Stef63 Link to post Share on other sites More sharing options...
moky99 Posted January 21, 2023 Author Share #3 Posted January 21, 2023 thanks Link to post Share on other sites More sharing options...
TomB_tx Posted January 21, 2023 Share #4 Posted January 21, 2023 The Voigtlander lenses (21 & 75) will bring up the same frame lines in the finder as equivalent FL Leica lenses. The frame lines are selected by the flange "ears" that have been standardized for decades. I think the only currently valid patent on the M mount relates to the 6-bit coding, which is not necessary for frameline selection, which is purely mechanical. 2 Link to post Share on other sites More sharing options...
moky99 Posted January 22, 2023 Author Share #5 Posted January 22, 2023 Thank you Link to post Share on other sites More sharing options...
