M9 with 90mm Elmarit-M. Cold and with a wind chill too.
  • Like 14
vor einer Stunde schrieb pgk:
Hello Paul!
Have you seen the magenta coloured spot in the middle? What is the reason for?
Best regards
Wolfgang
1 hour ago, wpo said:
Hello Paul!
Best regards
Wolfgang
Flare reflection from the filter and sensor. Not surprising with very bright and high contrast lighting. Taking the filter off might have helped but with salt soap around I didn't want to do so. I'm hppy enough with the image and could remove the magenta and boost contrast in the centre if I had to but I won't!
