BigBabyEarl Posted July 1, 2023 Share #21 Posted July 1, 2023 Advertisement (gone after registration) Picking this back up. Is there a filter that works best and also allows the cap? Or is it only cap/clean vs filter/ no cap? I’d rather not use the hood as I think it looks so clean and compact without. Love the lens. Link to post Share on other sites More sharing options...
Advertisement Posted July 1, 2023 Posted July 1, 2023 Hi BigBabyEarl, Take a look here Protective filter for 28mm f/5.6 Summaron re-issue. I'm sure you'll find what you were looking for!
Anbaric Posted July 1, 2023 Share #22 Posted July 1, 2023 26 minutes ago, BigBabyEarl said: Picking this back up. Is there a filter that works best and also allows the cap? Or is it only cap/clean vs filter/ no cap? I’d rather not use the hood as I think it looks so clean and compact without. Love the lens. Might be easier to find a cap that fits the filter than a filter that fits the cap. If the filter has a front thread, there are generic 34mm clip-on caps. Otherwise, you might try a push-on cap like those made by Kaiser, if the filter ring is deep enough to retain a cap. Link to post Share on other sites More sharing options...
graphlex Posted July 1, 2023 Share #23 Posted July 1, 2023 (edited) This one, on Amazon, fits onto the 34mm Heliopan UV filter: CamDesign Sides Pinch Snap-On Front Lens Cap/Cover Compatible with Canon, Nikon, Sony, Fujifilm Pentax All DSLR Lenses (34 MM) Edited July 1, 2023 by graphlex Add info Link to post Share on other sites More sharing options...
lifeandmylens Posted July 2, 2023 Share #24 Posted July 2, 2023 I used this with my summaron. It's super thin, schott glass and allowed for use of the cap. Would've been nicer if it was silver. Have to order from Japan. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/358731-protective-filter-for-28mm-f56-summaron-re-issue/?do=findComment&comment=4805762'>More sharing options...
BigBabyEarl Posted July 2, 2023 Share #25 Posted July 2, 2023 10 hours ago, lifeandmylens said: I used this with my summaron. It's super thin, schott glass and allowed for use of the cap. Would've been nicer if it was silver. Have to order from Japan. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! What brand? Link to post Share on other sites More sharing options...
lifeandmylens Posted July 2, 2023 Share #26 Posted July 2, 2023 1 minute ago, BigBabyEarl said: What brand? I think eins but not sure. Just listed mine on FM with a pic of the box https://www.fredmiranda.com/forum/topic/1815085 2 Link to post Share on other sites More sharing options...
Huss Posted July 2, 2023 Share #27 Posted July 2, 2023 Advertisement (gone after registration) Is it multi-coated? Link to post Share on other sites More sharing options...
lifeandmylens Posted July 2, 2023 Share #28 Posted July 2, 2023 9 minutes ago, Huss said: Is it multi-coated? This is what it says “It is a U-N original Ains super protect filter for classic lenses that pursues thinness without limit (1.2 mm thickness when installed).Using glass made by the world-famous glass manufacturer SCHOTT, water-repellent/oil-proof coat and ink-inking on the outer circumference of the lens have been applied to suppress the reflectance to 0.3% or less.The design is finished in a filter that adopts a nostalgic classic shape. ” 2 Link to post Share on other sites More sharing options...
Anbaric Posted July 2, 2023 Share #29 Posted July 2, 2023 (edited) 1 hour ago, lifeandmylens said: This is what it says “It is a U-N original Ains super protect filter for classic lenses that pursues thinness without limit (1.2 mm thickness when installed).Using glass made by the world-famous glass manufacturer SCHOTT, water-repellent/oil-proof coat and ink-inking on the outer circumference of the lens have been applied to suppress the reflectance to 0.3% or less.The design is finished in a filter that adopts a nostalgic classic shape. ” U.N is the company that makes these - the 'Meister' on the filter box is one of their brands, and 'Eins' seems to be what they call the Super Protect filter range. The 34mm UNX-9620 is here: https://www.un-ltd.co.jp/unx-9616unx-9626-en/ Does it fit the original cap that comes with the re-issued Summaron, or did you need to buy another cap? Looks like the filter doesn't have a front thread, so clip-on caps like the CamDesign mentioned above won't work. Incidentally, U.N make a lot of other nice accessories, many of which aren't widely available outside Japan. Their founder Mr.Sanai Sano apparently invented the blower brush ('The rubber shape of the blower brush was inspired by a compact taken out by a geisha who happened to be sitting in front of him when he took a bus on his way to a hot spring in Hakone.'). They also make what I think is the only metal ABLON-style film cutter guide currently in production. Edited July 2, 2023 by Anbaric Link to post Share on other sites More sharing options...
lifeandmylens Posted July 3, 2023 Share #30 Posted July 3, 2023 1 hour ago, Anbaric said: U.N is the company that makes these - the 'Meister' on the filter box is one of their brands, and 'Eins' seems to be what they call the Super Protect filter range. The 34mm UNX-9620 is here: https://www.un-ltd.co.jp/unx-9616unx-9626-en/ Does it fit the original cap that comes with the re-issued Summaron, or did you need to buy another cap? Looks like the filter doesn't have a front thread, so clip-on caps like the CamDesign mentioned above won't work. Incidentally, U.N make a lot of other nice accessories, many of which aren't widely available outside Japan. Their founder Mr.Sanai Sano apparently invented the blower brush ('The rubber shape of the blower brush was inspired by a compact taken out by a geisha who happened to be sitting in front of him when he took a bus on his way to a hot spring in Hakone.'). They also make what I think is the only metal ABLON-style film cutter guide currently in production. Thank you for that info. I have several of their filters and like how thin they are. From my recollection it fit just fine with the summaron cap (I no longer have the summaron even though I really like the lens). However, the are no front filter threads as you mentioned and it’s so thin that you need to be careful not to tighten it too tight or it might be difficult to unscrew. I’ll see if I have a picture of the lens with the filter on it. Link to post Share on other sites More sharing options...
lifeandmylens Posted July 3, 2023 Share #31 Posted July 3, 2023 10 hours ago, lifeandmylens said: I’ll see if I have a picture of the lens with the filter on it. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/358731-protective-filter-for-28mm-f56-summaron-re-issue/?do=findComment&comment=4806424'>More sharing options...
junix Posted July 4, 2023 Share #32 Posted July 4, 2023 21 hours ago, lifeandmylens said: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Looks nice, thnx for the photo. Were you able to use the lens hood together with the filter? Link to post Share on other sites More sharing options...
jpark114 Posted December 26, 2024 Share #33 Posted December 26, 2024 On 7/3/2023 at 6:00 AM, lifeandmylens said: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thank you so much for your great suggestion!! As for the cap, I deem the original cap to be way too loose fit, dropping from the lens way too often while taking out the camera & lens. And I've finally found a perfect alternative for it. 37.5mm pushon cap. Tried 37mm first, but it was way too tight, and 37.5 is just perfect. 1 Link to post Share on other sites More sharing options...
tappan Posted March 9 Share #34 Posted March 9 Does anybody know if the skylight (1A) filter dramatically changes the 28mm Summaron's color/image quality? Thanks. Because of such a small front element, it appears that it's gonna be a pain in the neck to keep it clean so yes I do want a filter. I am looking at a Heliopan 34mm skylight 1A but I have only used UV. Thank you, Mark Link to post Share on other sites More sharing options...
