Taking pictures indoor without flash light
thegyoza
Yo Ho~
I am using Leica MP without flash and Ilford Delta 400 film
I have this problems I have encountered several times
How can I take pictures indoor? I am sure you pro people can teach me how :D
...and yes, without flash :p
and in a street photography style^^
I don't really want to go high ISO tho
Not really a fan of tripod either...
Please help! Thanks
Gyo
Learn to use lower shutter speed, wider aperture, or even faster film.
I have pushed Kodak 3200 TMZ to 12,800 with T Max developer it has grain, but can get images in almost dark conditions.
This was shot from the hip at 1/4 @ F1.8 on Leica M4-P with Fuji Neopan Across (pushed 1 stop)
It was practically dark any noise you see is from the scanner/jpg incidentally (prints look better)
Mark
I guess the other comment would be to identify your subject and make your exposure decisions on that. Allow yourself to lose the background into a black void and recognise you have to adjust your composition. Even if you can get a good average exposure across the frame chances are parts that are important are going to be ouside the range of your film.
Using a Leica M indoors with 400 ASA is akin to shooting a rifle for accuracy.
One must learn how to hold for maximum staediness using any and all available rest points and breath control along with shutter control. Breath control is achieved by taking a breath in and letting it out part ways and then holding your breath. The intial intake allows you not to have to breath for a few moments while you slowly depress the shutter button. In rifle control, you never actually know when the gun will shoot and its the same with shutter control. As you become more familair with the tehcnique, it speeds up to where it can seem like normal picture taking to an outside observer.
I also use a motor M and believe it or not, it allows me faster steadier pictures when shooting in a sequence since I don't have to interrupt my hold on the camera to wind the film.
Resting your elbows on any available surface or the camera on a fixed surface allows a steadier rest and if all else fails, its the tripod!
Hope this helps.
Practise.-Dick
Hold the cam steady.
Expect no miracles.
It's only a Leica!
I use one daily and often fail.
Is pro making lots of money or doing a lot of photography.
Often payed, often not.
Posters, calendars, books, exhibits and all that, yes.
This is the real amateur speaking!
Don't expect tack sharp pics, make atmosphere, create the big picture and forget about the small details.
Lo light, lo fi!
Practice............... a lot;-)
MP, Fuji sensia 400, Lux 35 asph.
regards,
Francis
this pics is from a series I did for the dutch seafearers trust, on tour soon.
no one asked about sharpness, it's the sailor on board and ashore that counts.
The girl is no sailor, she's safe bihind the bar.
I agree with the notion above about breathing; learn to control it and steady your arms/hands, and you will be fine. I use even f2 lenses/delta 400 inside a home and get results I am happy with. I think with the summilux 50/1.4 and delta 3200 combination lets you shoot in almost any dim, candle-lit situation with good results.
If you have control over the lighting, you can add some tungsten lighting.
Get some reflectors from the hardware store (the kind that are used for work lights) and place 2 or 3 in various positions, so you bounce some extra light into the room. You add variable dimmers to these lights.
Thus, you avoid the impact of flash.
