achim Posted December 29, 2022 Share #1  Posted December 29, 2022 Advertisement (gone after registration) da kommt wohl im 1. Quartal 2023 eine neue S5 mit neuen Autofocus System und vielen Verbesserungen im Detail. siehe auch nachstehenden Link. http://thenewcamera.com/tag/panasonic-s5-mark-ii/ Panasonic S5 Mark II Full Specification effective pixel 24.2 megapixels full-size CMOS sensor, AR coating dust reduction is sensor-shift type Video is 6K30p 4:2:0 10-bit, C4K 60p 4:2:2 10-bit, Full HD 120fps 4: 2:0 10-bit, full HD 60fps 4:2:2 10-bit 3.68 million dots organic EL EVF, magnification 0.78x, eyepoint 21mm, refresh rate 120fps/60fps 3-inch 1.84 million dots free-angle monitor, touch panel, aspect ratio 3:2 AF method phase-detection AF/contrast AF, DFD, EV -6 – 18, AF assist light 1728 zone multi-pattern metering, metering range EV0-18 ISO range 100-51200 (50-204800 with extension) dual native ISO, Normal ISO 100 and 640, V-log 640 and 4000, HLG 400 and 2500 5-axis image stabilization, 5 steps effect (6.5 steps effect with dual IS 2) Shutter 1/8000-60 seconds (mechanical), 1/ 2000-60 seconds (electronic front curtain), 1/8000-60 seconds (electronic) , 1/250 second continuous shooting, 9 fps for AFS/MF, 7 fps for AFC (electronic Shutter) is AFS/AFC/MF and up to 30 frames per second. Buffer is 200 or more for RAW+JPEG, 200 or more for RAW, 300 or more for JPEG. USB Type-C port (USB3.2 Gen2) HDMI Type-A dual SD card slot Fan Auto/Auto 2/High speed/Normal/Slow/OFF Wi-Fi, Bluetooth v5.0 Battery life: 370 shots ), 657g (body only) Download the full specification from here DC-S5M2X 24.2-megapixel full-size sensor 6K30P video (full size) / 4K60P video (APS-C size) Supports Apple ProRes recording IP streaming function (Wi-Fi, USB, wired LAN) LUMIX S 14-28mm F4-5.6 MACRO lens construction: 14 elements in 10 groups (1 aspherical ED lens, 1 aspherical lens, 3 ED lenses, 1 UHR lens) Shortest shooting distance: 0.15m Maximum magnification: 0.5x (at 28mm) / 0.25x (at 14mm) Filter size: 77mm Size: φ84 x 89.8mm Weight : 345g Link to post Share on other sites More sharing options...
Advertisement Posted December 29, 2022 Posted December 29, 2022 Hi achim, Take a look here Panasonic Lumix S5 Mark II und S5X sowie 14-28/4-5,6 Rumors!. I'm sure you'll find what you were looking for!
hepcat Posted December 29, 2022 Share #2  Posted December 29, 2022 (edited) I don't see much there in the big scheme of things for improvements for still shooters.  I just bought an S5 as a backup to my S1 on the clearance deal with the 85mm f/1.8 for $1500. The lens arrived. The body is supposed to be here on Jan 3rd. Edited December 29, 2022 by hepcat Link to post Share on other sites More sharing options...
nords Posted January 2, 2023 Share #3 Â Posted January 2, 2023 Unfortunately Panasonic does not hear people. We've been asking all this time that we need 4K 60 from a full sensor because with apc crop that's a lot of trouble with optics. For filming this is simply unsuitable. Who needs this camera if the same thing stays again? Really for 3 years Panasonic could not invent how to make a reading from a full sensor? It's just incredible, we've been waiting for this second update to come out and it's useless. That's just terrible. This is probably because they left an old sensor that doesn't allow for a full sensor reading. Link to post Share on other sites More sharing options...
CL.art Posted January 2, 2023 Share #4  Posted January 2, 2023 Ein paar neue Infos https://www.photografix-magazin.de/panasonic-s5-mark-ii-zahlreiche-bilder-geleakt/ Kommt bald die SL3-S? 🤔 Link to post Share on other sites More sharing options...
MediaFotografie Posted January 4, 2023 Share #5  Posted January 4, 2023 und jetzt ist sie (oder besser: sind beide) wie erwartet da, die ersten Berichte klingen sehr positiv, insbesondere, was den Phasen-AF angeht https://www.panasonic.com/de/consumer/foto-video/lumix-s-wechselobjektivkameras/dc-s5m2.html https://www.panasonic.com/de/consumer/foto-video/lumix-s-wechselobjektivkameras/dc-s5m2x.html Link to post Share on other sites More sharing options...
Sonnelacht Posted January 5, 2023 Share #6  Posted January 5, 2023 Bin etwas verwundert: Panasonic stellt gerade den Prototypen einer SL3 / SL3s vor, der endlich in der AF-Technik zu den Mitbewerbern aufschließt, und hier interessiert das praktisch keinen... Link to post Share on other sites More sharing options...
Talker Posted January 5, 2023 Share #7  Posted January 5, 2023 Advertisement (gone after registration) vor 1 Minute schrieb Sonnelacht: Bin etwas verwundert: Panasonic stellt gerade den Prototypen einer SL3 / SL3s vor, der endlich in der AF-Technik zu den Mitbewerbern aufschließt, und hier interessiert das praktisch keinen... Wer ist denn Panasonic, na gut, vielleicht zur Not mal, aber sonst ist bei uns doch  Leica angesagt. 😎 2 Link to post Share on other sites More sharing options...
MediaFotografie Posted January 5, 2023 Share #8  Posted January 5, 2023 vor 4 Stunden schrieb Sonnelacht: Bin etwas verwundert: Panasonic stellt gerade den Prototypen einer SL3 / SL3s vor, der endlich in der AF-Technik zu den Mitbewerbern aufschließt, und hier interessiert das praktisch keinen... stimmt - aber im internationalen Forum ist es anders, dort gibt es viel Diskussion dazu; komisch… Link to post Share on other sites More sharing options...
satijntje Posted January 6, 2023 Share #9  Posted January 6, 2023 Habe mir gerade mal das 60 minutiges YT Video von Krolop & Gerst reingezogen. Die S2ii ist schon eine spannende Kamera. Ob Leica den gleichen Sensor bei der nächsten SL Generation einsetzen wird? Vielleicht ja für eine SL3-s, die SL3 wird bestimmt mehr Hubraum haben.  Link to post Share on other sites More sharing options...
Snooopy Posted January 6, 2023 Share #10  Posted January 6, 2023 vor 44 Minuten schrieb satijntje: Habe mir gerade mal das 60 minutiges YT Video von Krolop & Gerst reingezogen. Die S2ii ist schon eine spannende Kamera. Ob Leica den gleichen Sensor bei der nächsten SL Generation einsetzen wird? Vielleicht ja für eine SL3-s, die SL3 wird bestimmt mehr Hubraum haben. Der Prozessor sollte sicher in den neuen Leicas verbaut werden. Ob am Ende auch der gleiche AF kommt, wie bei der S5II wird man sehen. Wichtig war, dass Panasonic liefert, ansonsten hätte man langsam den L-Mount aufs Abstellens stellen können. Die neue S5II ist technisch und preislich wirklich ganz vorne mit dabei, für 1899€ mit der Trade-In Aktion bekommt man eine hervorragende Kamera. 1 Link to post Share on other sites More sharing options...
