frame-it Posted April 24, 2024 Share #21 Posted April 24, 2024 Advertisement (gone after registration) the lens ive been craving for quite a while and finally found & bought a mint copy last month has quite high radiation, the images are really nice. Link to post Share on other sites More sharing options...
Advertisement Posted April 24, 2024 Posted April 24, 2024 Hi frame-it, Take a look here Thorium lenses . I'm sure you'll find what you were looking for!
Anbaric Posted April 24, 2024 Share #22 Posted April 24, 2024 8 hours ago, frame-it said: the lens ive been craving for quite a while and finally found & bought a mint copy last month has quite high radiation, the images are really nice. That's about a dental X-ray an hour, isn't it? Another lens not to use as a loupe or keep in your trouser pocket! Link to post Share on other sites More sharing options...
nitroplait Posted April 25, 2024 Share #23 Posted April 25, 2024 20 hours ago, frame-it said: the lens ive been craving for quite a while and finally found & bought a mint copy last month has quite high radiation, the images are really nice. I don't know how fast reacting the meter is, but it looks like the readout drastically lowers just a few cm. away from the lens? Did you notice how the fall off was, say 5 or 10cm away? It could be interesting to measure just behind the camera - where your face is located in a normal shooting situation. I am guessing the shielding of the camera makes it is close to nothing. 11 µSv/h isn't much anyway, unless you sleep with it every night. You would have to hold it close to a body part for 150 hours to get as much radiation at that spot, as a flight attendant get exposed to from all sides on their hole body over a year. Link to post Share on other sites More sharing options...
Anbaric Posted April 25, 2024 Share #24 Posted April 25, 2024 If it were a point source, the dose reduction would follow the inverse square law - if you started 1cm away, the dose would drop to 1/25 of the original at 5cm, and to 1/100 at 10cm. The lens is a bit big to be considered a point source at these distances, but you should get roughly that reduction. But that's also why using one as a loupe would be bad. You get 100x the 1cm dose at 1mm, right next to a very radiation sensitive organ. Link to post Share on other sites More sharing options...
