I've been on a little creative 'hiatus' - working quite a lot but not really using my M stuff at all.
I'm looking to see who is the current recommendation for an M6 service. I bought it a few years back and it's cosmetically in great condition but I find the shutter speed dial isn't very easy to move. I think it may need a clean or someone said the pin may be bent but I don't know what the pin is, and I don't want to find out.
I think I went to Aperture in London ages ago and I wasn't overly convinced they'd be able to help when I chatted to them.
It may well be the way it is but I'd like someone who knows their stuff to take a look and then hopefully fix it. Might be worth giving it a CLA also whilst it's there.
Who/Where's the place to go these days?
Before taking it anywhere take a look yourself.  You will see there is a small philips head screw holding the shutter speed dial on.  Remove that screw, remove the dial and you should see another slotted screw underneath.  Slightly loosen that - by loosening it up then snugging it back up but not too much.  Reattach the shutter speed dial + screw and see if that makes a difference.
Any decent camera tech can check this for you if you dont want to.  You dont need to go to a Leica place for something like this.  You should be able to move the dial with one finger.
Edited by Huss
Well f-me that was easy. I remember taking the dial off when I got it to have a look but didn't want to mess. The screw under the dial was quite tightly in there so I undid and re-tightened and Im pretty sure it's made it tonnes better.
I need to look at another M6 to compare. I'm very used to the digital M's which have much smoother dials I think.
Cameraworks is the place to send Leicas it seems but looks like almost £500 for a full service. I was thinking £250 would be what the cost was.
Edited by satureyes
Nice!  In the owner's manual Leica recommends that if you do not use the camera, to exercise the shutter and all the bits that move several times every 3 months.
I would just sit there, turning the shutter speed dial for a while to let things loosen up some more.  I also have an M10 (as well as M7) and those have bigger shutter speed dials which are definitely a lot easier to turn than on my MP which has the same dial as your M6.
I would put some film in it, go out and use it, see the results then determine if you need a service.
