Moo1 Posted October 25, 2022 Share #1 Posted October 25, 2022 Advertisement (gone after registration) Hi My problem is that when I stop the aperture down so the image is under exposed and press the shutter button , upon release of the button after the image has been taken the whole evf and the if set the rear screen flashes white, it’s not clipping , clipping is turned off , it does this most of the time , the odd time it will not do it but most of the time it does it I have reset the camera and for a few pictures afterwards it stopped doing it , then the issue came back When I first got the camera ( recently) it did not do this Any ideas cheers Link to post Share on other sites More sharing options...
Advertisement Posted October 25, 2022 Posted October 25, 2022 Hi Moo1, Take a look here Odd white flash on evf and rear screen after pressing shutter. I'm sure you'll find what you were looking for!
RoySmith Posted October 25, 2022 Share #2 Posted October 25, 2022 I have not seen or heard of this, but it sounds like a hardware problem. To diagnose and fix it would require a trip to Leica. Is your camera under warranty? Link to post Share on other sites More sharing options...
Moo1 Posted October 25, 2022 Author Share #3 Posted October 25, 2022 Sadly is not Roy Not sure I can afford for it to go to Leica , what a shame as only had the camera a couple of months and love it .. Link to post Share on other sites More sharing options...
RoySmith Posted October 26, 2022 Share #4 Posted October 26, 2022 3 hours ago, Moo1 said: Sadly is not Roy Not sure I can afford for it to go to Leica , what a shame as only had the camera a couple of months and love it .. Does the flash of light in the EVF and LCD screen affect the image captured by the sensor? Link to post Share on other sites More sharing options...
Moo1 Posted October 26, 2022 Author Share #5 Posted October 26, 2022 No, it does not effect the image so guess I can live with it , just annoying Link to post Share on other sites More sharing options...
LexS Posted November 4, 2022 Share #6 Posted November 4, 2022 Why not asking a comment in the shop where you bought it, or another shop where they have "technical" support? Link to post Share on other sites More sharing options...
Moo1 Posted February 10, 2023 Author Share #7 Posted February 10, 2023 Advertisement (gone after registration) Sorry for late reply, I guess that’s a good idea ..need to find a shop close to me ..Brighton uk Link to post Share on other sites More sharing options...
DanF Posted March 25, 2024 Share #8 Posted March 25, 2024 I have a new Q3 and have noticed the same thing. When I press the shutter the EVF flashes bright white for a moment before showing the proper image. This has no effect on the recorded image but is a bit annoying. It's similar to what you'd see if you were using a strobe that flashed when you were looking through the viewfinder. I'm sure that it's the EVF going to maximum brightness for a moment before showing the properly exposed scene. I didn't notice this the first few times I used the camera, so I assume that it's some setting that I've accidentally messed up, but I'm not sure which of the settings it could be. Link to post Share on other sites More sharing options...
radialMelt Posted March 25, 2024 Share #9 Posted March 25, 2024 (edited) Q3 here and same behavior. However, it only happens in 2fps continuous mode. In single shot mode it doesn't happen. It's not like the entire screen flashes white. It's more like the exposure goes extremely bright for a split second after capture. Edited March 25, 2024 by radialMelt Link to post Share on other sites More sharing options...
SLamb Posted March 25, 2024 Share #10 Posted March 25, 2024 (edited) I have only had my Q3 for two weeks I have also experienced this. I can make it happen fairly regularly if I set the lens to F16 (which I rarely do), and it hardly ever occurs at any other apertures. Edited March 25, 2024 by SLamb Link to post Share on other sites More sharing options...
SLamb Posted March 26, 2024 Share #11 Posted March 26, 2024 14 hours ago, SLamb said: I have only had my Q3 for two weeks I have also experienced this. I can make it happen fairly regularly if I set the lens to F16 (which I rarely do), and it hardly ever occurs at any other apertures. Just to clarify, I get this flash when I half press the shutter button to focus. It does not happen after the picture is taken. Link to post Share on other sites More sharing options...
Casey Jefferson Posted March 26, 2024 Share #12 Posted March 26, 2024 Sounds like the dof preview and exposure preview conflicted, at smaller aperture it should display the view with actual aperture upon shootin, which the aperture will focus at wide aperture then stop down for preview, but if the exposure don't match it'll result in full blown preview... 1 Link to post Share on other sites More sharing options...
SLamb Posted March 26, 2024 Share #13 Posted March 26, 2024 A bit more information. When the camera is in Highlight Weighted (protection) metering mode the screen flashes white. If I change to Matrix metering mode, it flashes white and black. It appears as if it is showing the camera making the measurement of the scene brightness range to ascertain the correct exposure setting. White maybe to show the measurement of the highlights for the Highlight metering mode and white and black to assess the range from white to black in Matrix mode. It is definitely something that only happens when half-pressing the shutter button and other than focus the only thing happening would be metering of the scene. It isn't a big problem, unless it is isolated to only some Q3s in which case it may be faulty units. There do not seem to be many people reporting it, so either it is being accepted as just what happens or most people do not see this behaviour. Link to post Share on other sites More sharing options...
Luke_Miller Posted March 27, 2024 Share #14 Posted March 27, 2024 Can't speak to the Q3 since I have the Q2. With my camera if I am in Manual Mode the camera will disable Exposure Preview when I half press the shutter to begin autofocus. This causes a quick brighten or darken (depending on exposure settings) of the screen during autofocus. My SL bodies do the same. Link to post Share on other sites More sharing options...
