hirohhhh Posted October 18, 2022 Share #1  Posted October 18, 2022 (edited) Advertisement (gone after registration) Out of curiosity, I converted one SL2 multishot photo in Lightroom Classic using Library > Convert Photo to DNG and the file size was reduced by half. I selected medium preview, but even Full size preview doesn't change the size significantly. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Original file size was 340MB. After conversion with medium size preview 150MB After conversion with full size preview 170MB. Now, I'm curious, does this somehow affects the file? I'd like to reduce the file size on many multishot images I have in my library, but I don't want to screw something else. Any ideas to find this out? Edited October 18, 2022 by hirohhhh Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Original file size was 340MB. After conversion with medium size preview 150MB After conversion with full size preview 170MB. Now, I'm curious, does this somehow affects the file? I'd like to reduce the file size on many multishot images I have in my library, but I don't want to screw something else. Any ideas to find this out? ' data-webShareUrl='https://www.l-camera-forum.com/topic/341163-multishot-dng-file-half-size-after-conversion/?do=findComment&comment=4537732'>More sharing options...
Advertisement Posted October 18, 2022 Posted October 18, 2022 Hi hirohhhh, Take a look here Multishot DNG file half size after conversion. I'm sure you'll find what you were looking for!
jaapv Posted October 18, 2022 Share #2 Â Posted October 18, 2022 As you see, you did not tick "lossy compression", so the conversion will be lossless, which means that you can fully restore the original file. Link to post Share on other sites More sharing options...
hirohhhh Posted October 18, 2022 Author Share #3 Â Posted October 18, 2022 (edited) 6 minutes ago, jaapv said: As you see, you did not tick "lossy compression", so the conversion will be lossless, which means that you can fully restore the original file. I'm not concerned about the converted file. I'm curious how did it reduce the file size so much if I didn't choose Lossy Compression? Should I convert them all in that case? Why having 340MB files when I can have the same at 150MB? But I want to know what's going on in the background before I do this. Oh, and btw, I cannot fully restore it to the original file size anymore. After converting, it's always between 150-170MB. No matter what options I tick, it never gets back to 340MB. Edited October 18, 2022 by hirohhhh Link to post Share on other sites More sharing options...
jaapv Posted October 18, 2022 Share #4 Â Posted October 18, 2022 Not the file size, but the file content. Lossless compression works by removing redundancy. If the compression turns out to be effective, there was a lot of redundancy in the original file which is not surprising in this case. Link to post Share on other sites More sharing options...
hirohhhh Posted October 18, 2022 Author Share #5 Â Posted October 18, 2022 Got it, but how to know if I'd need this redundancy sometimes in the future? Maybe it's there for a reason. Link to post Share on other sites More sharing options...
hirohhhh Posted October 18, 2022 Author Share #6 Â Posted October 18, 2022 Converting regular single-shot DNG does not affect the file size at all, except when choosing smaller or larger preview size. Only multi-shot files has a signifficant change in the file size. Link to post Share on other sites More sharing options...
01af Posted October 18, 2022 Share #7 Â Posted October 18, 2022 Advertisement (gone after registration) A multi-shot capture has 187 megapixels. Each raw pixel is 14 bit. That's 2,618 megabit of image data, or 327.25 megabyte. Add some metadata, some profile data, plus one or two embedded JPEG previews, and you arrive at an image file with approx. 340 MB of uncompressed data. Converting DNG to DNG using Lightroom, Camera Raw, or DNG Converter will, by default, apply lossless compression to uncompressed data. That's why your files become significantly smaller. By the way, if Lightroom and/or Camera Raw are your preferred image processors then it will make sense to tick the 'Embed Fast-Load Data' option. A regular capture has 47 MP; at 14 bit per pixel that's approx. 82 MB of raw image data. Add some metadata and embedded JPEG previews, and then you'd get an uncompressed image file of approx. 85 - 90 MB. If your image files are significantly smaller than that then they have been compressed, so Lightroom won't be able to compress them any further (at least not losslessly). 1 Link to post Share on other sites More sharing options...
jaapv Posted October 18, 2022 Share #8  Posted October 18, 2022 lol 11 hours ago, hirohhhh said: Got it, but how to know if I'd need this redundancy sometimes in the future? Maybe it's there for a reason. Wel, the very essence of redundancy is that it is, errm, redundant. Link to post Share on other sites More sharing options...
