SL2S Perspective control not working with R-Lenses (manually selected)
I've installed latest firmware, mounted a 135 Elmarit 11211 and selected relative profile from R-Lenses list. Perspective control is not working. If I select Other Lenses->135mm perspective control do works. It works too, if I mount a Rom-Lens. The problem ist with non ROM lenses selected from R-Lenses List.
Does anybody have same problem?
I tried with every non ROM lenses I own. If I select them from R-Lenses list perspective doesn't work, rectangle stay fix in red colour. If I select Other lenses and then focal, it works perfectly. The adapter is the original Leica L-R.
Edited by sarav
