Santos Posted August 25, 2022 Share #1 Posted August 25, 2022 (edited) Advertisement (gone after registration) Dear All, After Investing And Building My CL System (Which Was My Crop M System Basically With Some AF Lenses) I Got Demoralized When I Heard That The ASPC Was Not Being Developed Inhouse At Least. Hence, I Decided I Will IR My Camera! (All Documented In MY Insta Stories) Was Such A Beautifully Designed Machine The Efficiency Inside Matching The Outside! Only 5 Ribbon Cables To Worry About Really, And A Total Of Around 30 Screws Easily Differentiated By Color Codes! Once Done I Used My 55-135 With Kolarvision Filter To Only Keep The Visual And IR Spectrum. Removing The Tiny Light Blue Filter On Top Of The Sensor Made It All Spectrum. (I Now Believe After Taking Measurements, I Can Do The Conversion With Just Lens Unmounted, But Please Let Me Waste My Money Do not Break Your Gear!). So Below Is An Image Of Dubai Skyline (Some Green Trees To Show IR Effect). Shot At ISO 12k If I Remember Correctly, This Due To Early Dawn, I Apologize For The Noise. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! S.T.Keeler. Edited August 25, 2022 by Santos Typo 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! S.T.Keeler. ' data-webShareUrl='https://www.l-camera-forum.com/topic/335928-my-infrared-cl/?do=findComment&comment=4496658'>More sharing options...
Advertisement Posted August 25, 2022 Posted August 25, 2022 Hi Santos, Take a look here My Infrared CL. I'm sure you'll find what you were looking for!
tommonego@gmail.com Posted August 25, 2022 Share #2 Posted August 25, 2022 (edited) While the CL definitely has an IR filter onthe sensor, it isn't that strong. You can use an R72 filter and at ISO 800 f5.6 get 1-2 second exposures. You don't get hand held IR unless you jack up the ISO. One nice thing is the EVF compensates for the filter and you can compose with the filter in place. I like doing IR with WA lenses at medium f stops so you don't have to worry (that much) about the IR focus shift. Not hand holdable though. You are far more daring than I would be, glad it worked out. CL 23 Summicron, Hoya R72 filter ISO 800 f5.6 2.5 seconds. A little color channel mixing. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 25, 2022 by tommonego@gmail.com 2 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/335928-my-infrared-cl/?do=findComment&comment=4496798'>More sharing options...
Santos Posted August 26, 2022 Author Share #3 Posted August 26, 2022 Amazing Work Mr. Tommonego! Yeah I Can Be A Bit "Chaotic Good" When I Get Frustrated, The CL Ate It Lol. I Will Try That Filter On It! I Got One For My SFX Film. And The Method Of Converting To IR In Like A Minute That I'm Working On, I Will Test On A TL, Then TL2. And Then Ill Share! I m Thinking Of Two Methods. One Involves Removing The Filter "Easiest Way Really" I Will Try To Remove The Coating On The Light Blue Filter Infront Of The Sensor Hoping Its Coated On The None Sensor Facing Side. But I'm So Happy TL/CL Are Being Used And Will Be Used As IR. To This Day I Don't Think I've Seen As Tight Of A Body As The TL2 (Software/Hardware Integration Is Perfect. S.T.Keeler Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted August 26, 2022 Share #4 Posted August 26, 2022 Most of the time I use my M8 for IR, as its IR filter is very weak, in fact you need an IR blocking filter for color. Anyway you can hand hold with an R72, B+W 092 or the stronger B+W 093. I also use an M3 and Rolleiflex with Rollei IR 400. 1 Link to post Share on other sites More sharing options...
jaapv Posted August 27, 2022 Share #5 Posted August 27, 2022 An IR filter works with the glass body filtering out the IR light. Removing coating will have only a minimal effect if any. How do you propose doing so without destroying the surface? One thing amazes me. Why is a camera suddenly unusable when it has no successor? The future does not affect the present. 2 Link to post Share on other sites More sharing options...
Bill Valenti Posted October 17, 2022 Share #6 Posted October 17, 2022 Just started experimenting with IR filter on my M10M, and curious as to why Leica does not have the red line on the lens barrel to accommodate IR focal shift. Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted October 18, 2022 Share #7 Posted October 18, 2022 Advertisement (gone after registration) vor 16 Stunden schrieb Bill Valenti: Just started experimenting with IR filter on my M10M, and curious as to why Leica does not have the red line on the lens barrel to accommodate IR focal shift. Hmmm all my older M lenses have a marking. I suspect after Kodak discontinued HIE in what the late 1970s lens manufacturers figured they could stop putting on the infrared markings, though my 18mm Zeiss built between 2006 and 2016 has the IR marking. I used to use just WA lenses for IR and at least f5.6. My favorite was a 25mm Nikkor on a IIIc, the M8 with the 18 Zeiss comes close just not as small. With a WA and high fstop you don't have to be really concerned with the IR focus point. Link to post Share on other sites More sharing options...
DenverSteve Posted October 27, 2022 Share #8 Posted October 27, 2022 I would opt for the easier, cheaper and (to me) sharper/better results by doing it in post. That way you're not damaging or modifying your camera and retain the option of shooting in color, b&w & infrared, although simulated the results are great. Link to post Share on other sites More sharing options...
